dknightd
Aug 18, 2016Aspirant
Two disks apparently failed in ReadyNAS Pro 6
Hi, We have a readyNAS pro 6. One of the disks failed. While trying to rebuild the raid group another disk failed part way through the process. Unfortunately the people using the device ...
- Aug 18, 2016
You can contact netgear (my.netgear.com) and ask about data recovery.
If you can clone either of the failed drives (ideally both), then it might be possible to mount the array, though there will likely be some corruption.
Aug 18, 2016Guru - Experienced User
