Max_1968
Jan 09, 2015Aspirant
Ultra 4 messed up after apt-get dist-upgrade
Hi, it seems I have messed up my Ultra 4 by mistake, would like to know if i can get it working again without full reinit. Basically I was on 4.2.27, but I have made many manual changes to the s...
mdgm-ntgr
Jan 10, 2015NETGEAR Employee Retired
You'd be best to backup your data if you haven't already and to put OS6 on your system if you want to use Wheezy. Using OS6 you'd also get the newer kernel that has. Do note that if you use OS6 and run into issues running it on a legacy system you will need to seek help here or from a 3rd party.
