Max_1968
Jan 09, 2015Aspirant
Ultra 4 messed up after apt-get dist-upgrade
Hi, it seems I have messed up my Ultra 4 by mistake, would like to know if i can get it working again without full reinit. Basically I was on 4.2.27, but I have made many manual changes to the s...
Max_1968
Jan 24, 2015Aspirant
Thx mdgm, that was expected...
I have backed up all the important data on the Ultra 4 to an old NV+, and the most important data to additionally to an external USB drive... Still I have some data on the Ultra that is not really important, however I would like to avoid to loose it.
Can i use disk striping on the NV+, meaning having 4 disks 2 GB each in it with a total capacity of 8 GB ? Reason I'm asking this is I have roughly 7.5 GB in use on the Ultra 4 in total and would like to do a full backup of it to the NV+... It seems i have no way to configure what RAID is used on the NV+, correct ? 2 GB disks for that old system is still the limit ?
Thx again,
Max
Thx again,
Max
