Quinny1
Apr 09, 2015Aspirant
Ultra 6 - Dead drive, Replaced but won't Rebuild #24999085
I have a ReadyNAS Ultra 6 in Raid 6 which was 98% full. RAIDiator 4.2.25 Wed Jan 7 12:56:48 NZDT 2015 Disk failure detected. Wed Jan 7 12:57:01 NZDT 2015 ..... If this disk is a part of a RAI...
Quinny1
Is this it? expansion.log? Nothing called expand_md but mentioned it.
[2014/09/09 20:46:26 2097] Boot, handle mutiple expand_md
[2014/09/09 20:46:27 2098] STAGE_CHECK: saved my_pid 2098 in check mode.
[2014/09/09 20:46:27 2098] RAID MODE: 1, sn=
[2014/09/09 20:46:28 2098] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2014/09/09 20:46:28 2098] Current file system status: ext4
[2014/09/09 20:46:28 2098] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2014/09/09 20:46:28 2098] X_level: 6
[2014/09/09 20:46:28 2098] /usr/sbin/expand_md
[2014/09/09 20:46:28 2098] MD degraded 0, bg_job 0, boot 1
[2014/09/09 20:46:29 2098] Read 1957072 byte from configuration
[2014/09/09 20:46:29 2098] Disk configuration matching with online configuration.
[2014/09/09 20:46:29 2098] gpt sig:0,mbr sig:0,fake type:0
[2014/09/09 20:46:29 2098] get disk /dev/sda format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2014/09/09 20:46:29 2098] /dev/sda used/total/partitioned = 2930264504/2930266584/2930264504, 60000000
[2014/09/09 20:46:29 2098] get disk /dev/sdb format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2014/09/09 20:46:29 2098] /dev/sdb used/total/partitioned = 2930264504/2930266584/2930264504, 60000000
[2014/09/09 20:46:29 2098] get disk /dev/sdc format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2014/09/09 20:46:29 2098] /dev/sdc used/total/partitioned = 2930264504/2930266584/2930264504, 60000000
[2014/09/09 20:46:29 2098] get disk /dev/sdd format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2014/09/09 20:46:29 2098] /dev/sdd used/total/partitioned = 2930264504/2930266584/2930264504, 60000000
[2014/09/09 20:46:29 2098] get disk /dev/sde format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2014/09/09 20:46:29 2098] /dev/sde used/total/partitioned = 2930264504/2930266584/2930264504, 60000000
[2014/09/09 20:46:29 2098] get disk /dev/sdf format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2014/09/09 20:46:29 2098] /dev/sdf used/total/partitioned = 2930264504/2930266584/2930264504, 60000000
[2014/09/09 20:46:29 2098] Not enough disk for a new array, drives with free space: 0, X_level:6
[2014/09/09 20:46:29 2098] LINE 4939: exec command: ps -ef | grep expand_md | grep -v grep > /var/log/frontview/.V_E.snapshotstat
[2014/09/09 20:46:29 2098] STAGE_WIPE: Clean my_pid 2098
[2014/09/22 06:34:25 2104] Boot, handle mutiple expand_md
[2014/09/22 06:34:26 2105] STAGE_CHECK: saved my_pid 2105 in check mode.
[2014/09/22 06:34:26 2105] RAID MODE: 1, sn=
[2014/09/22 06:34:26 2105] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2014/09/22 06:34:27 2105] Current file system status: ext4
[2014/09/22 06:34:27 2105] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2014/09/22 06:34:27 2105] X_level: 6
[2014/09/22 06:34:27 2105] /usr/sbin/expand_md
[2014/09/22 06:34:27 2105] MD degraded 0, bg_job 0, boot 1
[2014/09/22 06:34:27 2105] Read 1957072 byte from configuration
[2014/09/22 06:34:27 2105] Disk configuration matching with online configuration.
[2014/09/22 06:34:27 2105] gpt sig:0,mbr sig:0,fake type:0
[2014/09/22 06:34:27 2105] get disk /dev/sda format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2014/09/22 06:34:27 2105] /dev/sda used/total/partitioned = 2930264504/2930266584/2930264504, 60000000
[2014/09/22 06:34:27 2105] get disk /dev/sdb format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2014/09/22 06:34:27 2105] /dev/sdb used/total/partitioned = 2930264504/2930266584/2930264504, 60000000
[2014/09/22 06:34:27 2105] get disk /dev/sdc format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2014/09/22 06:34:27 2105] /dev/sdc used/total/partitioned = 2930264504/2930266584/2930264504, 60000000
[2014/09/22 06:34:27 2105] get disk /dev/sdd format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2014/09/22 06:34:27 2105] /dev/sdd used/total/partitioned = 2930264504/2930266584/2930264504, 60000000
[2014/09/22 06:34:27 2105] get disk /dev/sde format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2014/09/22 06:34:27 2105] /dev/sde used/total/partitioned = 2930264504/2930266584/2930264504, 60000000
[2014/09/22 06:34:27 2105] get disk /dev/sdf format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2014/09/22 06:34:27 2105] /dev/sdf used/total/partitioned = 2930264504/2930266584/2930264504, 60000000
[2014/09/22 06:34:27 2105] Not enough disk for a new array, drives with free space: 0, X_level:6
[2014/09/22 06:34:27 2105] LINE 4939: exec command: ps -ef | grep expand_md | grep -v grep > /var/log/frontview/.V_E.snapshotstat
[2014/09/22 06:34:29 2105] STAGE_WIPE: Clean my_pid 2105
[2015/02/07 14:06:52 2098] Boot, handle mutiple expand_md
[2015/02/07 14:06:53 2099] STAGE_CHECK: saved my_pid 2099 in check mode.
[2015/02/07 14:06:53 2099] RAID MODE: 1, sn=
[2015/02/07 14:06:58 2099] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2015/02/07 14:08:00 2099] Current file system status: offline
[2015/02/07 14:08:00 2099] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2015/02/07 14:08:59 2099] Adjust used size on /dev/sdd Used/total/partitioned=2930266584/2930264504/2930264504, -(not used)2925545912
[2015/02/07 14:08:59 2099] X_level: 6
[2015/02/07 14:08:59 2099] /usr/sbin/expand_md
[2015/02/07 14:08:59 2099] MD degraded 1, bg_job 0, boot 1
[2015/02/07 14:09:00 2099] Read 1957072 byte from configuration
[2015/02/07 14:09:00 2099] Disk configuration matching with online configuration.
[2015/02/07 14:09:00 2099] May need to fix array.
[2015/02/07 14:09:00 2099] ===== Partition Entry (Used by MD) =====
[2015/02/07 14:09:00 2099] 000 /dev/sda,WD-WCAWZ1982796,8, 0, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/02/07 14:09:00 2099] partitions: 3 property: 4K
[2015/02/07 14:09:00 2099] 000 /dev/sda1, 8, 1, 4194304 MD_FULL md=/dev/md0
[2015/02/07 14:09:00 2099] 001 /dev/sda2, 8, 2, 524288 MD_FULL md=/dev/md1
[2015/02/07 14:09:00 2099] 002 /dev/sda3, 8, 3, 2925545912 MD_FULL md=/dev/md2
[2015/02/07 14:09:00 2099] 001 /dev/sdb,WD-WCAWZ2042830,8, 16, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/02/07 14:09:00 2099] 000 /dev/sdb1, 8, 17, 4194304 MD_FULL md=/dev/md0
[2015/02/07 14:09:00 2099] 001 /dev/sdb2, 8, 18, 524288 MD_FULL md=/dev/md1
[2015/02/07 14:09:00 2099] 002 /dev/sdb3, 8, 19, 2925545912 MD_FULL md=/dev/md2
[2015/02/07 14:09:00 2099] 002 /dev/sdc,WD-WCAWZ2059262,8, 32, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/02/07 14:09:00 2099] 000 /dev/sdc1, 8, 33, 4194304 MD_FULL md=/dev/md0
[2015/02/07 14:09:00 2099] 001 /dev/sdc2, 8, 34, 524288 MD_FULL md=/dev/md1
[2015/02/07 14:09:00 2099] 002 /dev/sdc3, 8, 35, 2925545912 MD_FULL md=/dev/md2
[2015/02/07 14:09:00 2099] 003 /dev/sdd,WD-WCAWZ1978251,8, 48, 2930266584 4718592 2930264504 MD_PART 0
[2015/02/07 14:09:00 2099] 000 /dev/sdd1, 8, 49, 4194304 MD_FULL md=/dev/md0
[2015/02/07 14:09:00 2099] 001 /dev/sdd2, 8, 50, 524288 MD_FULL md=/dev/md1
[2015/02/07 14:09:00 2099] 002 /dev/sdd3, 8, 51, 2925545912 NO_MD md=
[2015/02/07 14:09:00 2099] 004 /dev/sde,WD-WCAWZ2059507,8, 64, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/02/07 14:09:00 2099] 000 /dev/sde1, 8, 65, 4194304 MD_FULL md=/dev/md0
[2015/02/07 14:09:00 2099] 001 /dev/sde2, 8, 66, 524288 MD_FULL md=/dev/md1
[2015/02/07 14:09:00 2099] 002 /dev/sde3, 8, 67, 2925545912 MD_FULL md=/dev/md2
[2015/02/07 14:09:00 2099] 005 /dev/sdf,WD-WCAWZ2042889,8, 80, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/02/07 14:09:00 2099] 000 /dev/sdf1, 8, 81, 4194304 MD_FULL md=/dev/md0
[2015/02/07 14:09:00 2099] 001 /dev/sdf2, 8, 82, 524288 MD_FULL md=/dev/md1
[2015/02/07 14:09:00 2099] 002 /dev/sdf3, 8, 83, 2925545912 MD_FULL md=/dev/md2
[2015/02/07 14:09:00 2099] disk and pt index: /dev/sda 0 2 size=2925545912 cfg=MD_FULL
[2015/02/07 14:09:00 2099] disk and pt index: 0 0 size=4194304 s_name1 = MD_FULL, s_name = /dev/sda1
[2015/02/07 14:09:00 2099] disk and pt index: 0 1 size=524288 s_name1 = MD_FULL, s_name = /dev/sda2
[2015/02/07 14:09:00 2099] disk and pt index: 0 2 size=2925545912 s_name1 = MD_FULL, s_name = /dev/sda3
[2015/02/07 14:09:00 2099] disk and pt index: 1 0 size=4194304 s_name1 = MD_FULL, s_name = /dev/sdb1
[2015/02/07 14:09:00 2099] disk and pt index: 1 1 size=524288 s_name1 = MD_FULL, s_name = /dev/sdb2
[2015/02/07 14:09:00 2099] disk and pt index: 1 2 size=2925545912 s_name1 = MD_FULL, s_name = /dev/sdb3
[2015/02/07 14:09:00 2099] disk and pt index: 2 0 size=4194304 s_name1 = MD_FULL, s_name = /dev/sdc1
[2015/02/07 14:09:00 2099] disk and pt index: 2 1 size=524288 s_name1 = MD_FULL, s_name = /dev/sdc2
[2015/02/07 14:09:00 2099] disk and pt index: 2 2 size=2925545912 s_name1 = MD_FULL, s_name = /dev/sdc3
[2015/02/07 14:09:00 2099] disk and pt index: 3 0 size=4194304 s_name1 = MD_FULL, s_name = /dev/sdd1
[2015/02/07 14:09:00 2099] disk and pt index: 3 1 size=524288 s_name1 = MD_FULL, s_name = /dev/sdd2
[2015/02/07 14:09:00 2099] disk and pt index: 3 2 size=2925545912 s_name1 = NO_MD, s_name = /dev/sdd3
[2015/02/07 14:09:00 2099] NEED TO ADD DRIVE /dev/sdd3 INTO MD /dev/md2, this is a problem,may be caused by reboot system before added disk sync all arrays,blindly add this drive back to the array.
mdadm: re-added /dev/sdd3
[2015/02/07 14:09:00 2099] LINE 5018: exec command: mdadm -a /dev/md2 /dev/sdd3
[2015/02/07 14:09:01 2099] LINE 3152: exec command: echo 100000 > /sys/block/md2/md/sync_speed_min
[2015/02/07 14:10:38 2099] LINE 3155: exec command: mdadm --misc -W /dev/md2
[2015/02/07 14:14:52 2099] Array /dev/md2 still not ok after wait_md, err:1
[2015/02/07 14:14:52 2099] Wait md add failed on 136601472, This array will de degraded.
[2015/02/07 14:14:52 2099] LINE 4852: exec command: /usr/sbin/expand_md -a super >> /var/log/frontview/expand_md.log 2>&1 &
[2015/02/07 14:15:12 2099] LINE 4855: exec command: /frontview/bin/volumescan &
[2015/02/07 14:15:16 2099] LINE 4939: exec command: ps -ef | grep expand_md | grep -v grep > /var/log/frontview/.V_E.snapshotstat
[2015/02/07 14:15:20 2099] STAGE_WIPE: Clean my_pid 2099
[2015/02/07 14:15:54 12705] STAGE_CHECK: saved my_pid 12705 in check mode.
[2015/02/07 14:15:55 12705] RAID MODE: 1, sn=
[2015/02/07 14:15:55 12705] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2015/02/07 14:16:04 12705] Current file system status: ext4
[2015/02/07 14:16:04 12705] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2015/02/07 14:16:12 12705] X_level: 6
[2015/02/07 14:16:12 12705] /usr/sbin/expand_md -a super
[2015/02/07 14:16:12 12705] MD degraded 1, bg_job 0, boot 0
[2015/02/07 14:16:12 12705] STAGE_WIPE: Clean my_pid 12705
[2015/03/08 19:49:50 2112] Boot, handle mutiple expand_md
[2015/03/08 19:49:51 2113] STAGE_CHECK: saved my_pid 2113 in check mode.
[2015/03/08 19:49:51 2113] RAID MODE: 1, sn=
[2015/03/08 19:49:52 2113] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2015/03/08 19:49:52 2113] Current file system status: offline
[2015/03/08 19:49:52 2113] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2015/03/08 19:49:52 2113] Running disk SMART quick self-test on new disk 4 [/dev/sdd]...
[2015/03/08 19:51:57 2113] PASSED
[2015/03/08 19:51:58 2113] LINE 1144: exec command: killall -HUP monitor_enclosure
[2015/03/08 19:51:58 2113] X_level: 6
[2015/03/08 19:51:58 2113] /usr/sbin/expand_md
[2015/03/08 19:51:58 2113] MD degraded 1, bg_job 0, boot 1
[2015/03/08 19:51:58 2113] Read 1957072 byte from configuration
[2015/03/08 19:51:58 2113] Disk configuration matching with online configuration.
[2015/03/08 19:51:58 2113] May need to fix array.
[2015/03/08 19:51:58 2113] new_disk_pt_count: 1
[2015/03/08 19:51:58 2113] * new disk: /dev/sdd
[2015/03/08 19:51:58 2113] ===== Partition Entry (MD not used) =====
[2015/03/08 19:51:58 2113] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 0 0 NO_MD 0
[2015/03/08 19:51:58 2113] partitions: 0 property: UNKNOWN
[2015/03/08 19:51:58 2113] ===== Partition Entry (Used by MD) =====
[2015/03/08 19:51:58 2113] 000 /dev/sda,WD-WCAWZ1982796,8, 0, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/08 19:51:58 2113] partitions: 3 property: 4K
[2015/03/08 19:51:58 2113] 000 /dev/sda1, 8, 1, 4194304 MD_FULL md=/dev/md0
[2015/03/08 19:51:58 2113] 001 /dev/sda2, 8, 2, 524288 MD_FULL md=/dev/md1
[2015/03/08 19:51:58 2113] 002 /dev/sda3, 8, 3, 2925545912 MD_FULL md=/dev/md2
[2015/03/08 19:51:58 2113] 001 /dev/sdb,WD-WCAWZ2042830,8, 16, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/08 19:51:58 2113] 000 /dev/sdb1, 8, 17, 4194304 MD_FULL md=/dev/md0
[2015/03/08 19:51:58 2113] 001 /dev/sdb2, 8, 18, 524288 MD_FULL md=/dev/md1
[2015/03/08 19:51:58 2113] 002 /dev/sdb3, 8, 19, 2925545912 MD_FULL md=/dev/md2
[2015/03/08 19:51:58 2113] 002 /dev/sdc,WD-WCAWZ2059262,8, 32, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/08 19:51:58 2113] 000 /dev/sdc1, 8, 33, 4194304 MD_FULL md=/dev/md0
[2015/03/08 19:51:58 2113] 001 /dev/sdc2, 8, 34, 524288 MD_FULL md=/dev/md1
[2015/03/08 19:51:58 2113] 002 /dev/sdc3, 8, 35, 2925545912 MD_FULL md=/dev/md2
[2015/03/08 19:51:58 2113] 003 /dev/sde,WD-WCAWZ2059507,8, 64, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/08 19:51:58 2113] 000 /dev/sde1, 8, 65, 4194304 MD_FULL md=/dev/md0
[2015/03/08 19:51:58 2113] 001 /dev/sde2, 8, 66, 524288 MD_FULL md=/dev/md1
[2015/03/08 19:51:58 2113] 002 /dev/sde3, 8, 67, 2925545912 MD_FULL md=/dev/md2
[2015/03/08 19:51:58 2113] 004 /dev/sdf,WD-WCAWZ2042889,8, 80, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/08 19:51:58 2113] 000 /dev/sdf1, 8, 81, 4194304 MD_FULL md=/dev/md0
[2015/03/08 19:51:58 2113] 001 /dev/sdf2, 8, 82, 524288 MD_FULL md=/dev/md1
[2015/03/08 19:51:58 2113] 002 /dev/sdf3, 8, 83, 2925545912 MD_FULL md=/dev/md2
[2015/03/08 19:51:58 2113] in find_drive_... looking at /dev/md2
[2015/03/08 19:51:58 2113] found drive has the needed size for /dev/md2: /dev/sdf, 2930266584, 2930264504
[2015/03/08 19:51:58 2113] Drive sn WD-WCAWZ1982796
[2015/03/08 19:51:58 2113] Drive sn WD-WCAWZ1982796 WD-WCAWZ1982796
[2015/03/08 19:51:58 2113] Take /dev/sda WD-WCAWZ1982796 away
[2015/03/08 19:51:58 2113] Drive sn WD-WCAWZ2042830
[2015/03/08 19:51:58 2113] Drive sn WD-WCAWZ2042830 WD-WCAWZ2042830
[2015/03/08 19:51:58 2113] Take /dev/sdb WD-WCAWZ2042830 away
[2015/03/08 19:51:58 2113] Drive sn WD-WCAWZ2059262
[2015/03/08 19:51:58 2113] Drive sn WD-WCAWZ2059262 WD-WCAWZ2059262
[2015/03/08 19:51:58 2113] Take /dev/sdc WD-WCAWZ2059262 away
[2015/03/08 19:51:58 2113] Drive sn WD-WCAWZ1978251
[2015/03/08 19:51:58 2113] Drive WD-WCAWZ1978251 missing.
[2015/03/08 19:51:58 2113] Drive sn WD-WCAWZ2059507
[2015/03/08 19:51:58 2113] Drive sn WD-WCAWZ2059507 WD-WCAWZ2059507
[2015/03/08 19:51:58 2113] Take /dev/sde WD-WCAWZ2059507 away
[2015/03/08 19:51:58 2113] Drive sn WD-WCAWZ2042889
[2015/03/08 19:51:58 2113] Drive sn WD-WCAWZ2042889 WD-WCAWZ2042889
[2015/03/08 19:51:58 2113] Take /dev/sdf WD-WCAWZ2042889 away
[2015/03/08 19:51:58 2113] Total missing: 1, index=3
[2015/03/08 19:51:58 2113] found missing drive: /dev/sdd WD-WCAWZ1978251 MD_NULL blocks=2930266584 2930264504 2930264504
[2015/03/08 19:51:58 2113] XRAID cfg_pt = WD-WCAWZ2042889, these two drives size close: 0 /dev/sdd 2930266584, 0 /dev/sda 2930266584
[2015/03/08 19:51:58 2113] Changed drive selction: s=4/0, t=0/0, file=/var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
[2015/03/08 19:51:59 2113] Repair md: use disk /dev/sdd, size 2930266584
[2015/03/08 19:52:02 2113] LINE 1505: exec command: sgdisk -Z /dev/sdd
Creating new GPT entries.
GPT data structures destroyed! You may now partition the disk using fdisk or
other utilities.
[2015/03/08 19:52:06 2113] Update new added disk information: from /dev/sdf to /dev/sdd
[2015/03/08 19:52:06 2113] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 0 0 NO_MD 0
[2015/03/08 19:52:06 2113] partitions: 0 property: UNKNOWN
[2015/03/08 19:52:06 2113] 000 /dev/sdf,WD-WCAWZ2042889,8, 80, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/08 19:52:06 2113] partitions: 3 property: 4K
[2015/03/08 19:52:06 2113] 000 /dev/sdf1, 8, 81, 4194304 MD_FULL md=/dev/md0
[2015/03/08 19:52:06 2113] 001 /dev/sdf2, 8, 82, 524288 MD_FULL md=/dev/md1
[2015/03/08 19:52:06 2113] 002 /dev/sdf3, 8, 83, 2925545912 MD_FULL md=/dev/md2
[2015/03/08 19:52:06 2113] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 2930264504 2930264504 NO_MD 0
[2015/03/08 19:52:06 2113] partitions: 3 property: UNKNOWN
[2015/03/08 19:52:06 2113] 000 /dev/sdd1, 0, 0, 4194304 NO_MD md=
[2015/03/08 19:52:06 2113] 001 /dev/sdd2, 0, 0, 524288 NO_MD md=
[2015/03/08 19:52:06 2113] 002 /dev/sdd3, 0, 0, 2925545912 NO_MD md=
[2015/03/08 19:52:06 2113] Get format of pt /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
[2015/03/08 19:52:06 2113] Error unkonwn partition table /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889 !!!!
[2015/03/08 19:52:06 2113] Need to increase ext size from 0 to 0
[2015/03/08 19:52:06 2113] LINE 3717: exec command: sfdisk --force -L /dev/sdd < /var/log/frontview/.V_E.source_pt1.sav
Disk /dev/sdd: 364801 cylinders, 255 heads, 63 sectors/track
sfdisk: ERROR: sector 0 does not have an msdos signature
/dev/sdd: unrecognized partition table type
Old situation:
No partitions found
New situation:
No partitions found
sfdisk: no partition table present.
[2015/03/08 19:52:07 2113] Input target disk 4K align partition problem: 256, use old partition.
[2015/03/08 19:52:07 2113] LINE 3723: exec command: sfdisk --force -L /dev/sdd < /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
Old situation:
No partitions found
New situation:
No partitions found
[2015/03/08 19:52:07 2113] LINE 3730: exec command: sgdisk -g -a 8 /dev/sdd
The operation has completed successfully.
[2015/03/08 19:52:10 2113] Succeed to convert mbr to gpt /dev/sda.
[2015/03/08 19:52:10 2113] Input target disk partition problem: 256
[2015/03/08 19:52:10 2113] Failed to add disk to md
[2015/03/08 19:52:10 2113] Added drive to md, grown=0/0xffaeb6c8
[2015/03/08 19:52:10 2113] LINE 4852: exec command: /usr/sbin/expand_md -a super >> /var/log/frontview/expand_md.log 2>&1 &
[2015/03/08 19:52:10 2113] LINE 4855: exec command: /frontview/bin/volumescan &
[2015/03/08 19:52:10 2113] LINE 4939: exec command: ps -ef | grep expand_md | grep -v grep > /var/log/frontview/.V_E.snapshotstat
[2015/03/08 19:52:11 2113] STAGE_WIPE: Clean my_pid 2113
[2015/03/08 19:52:11 5911] STAGE_CHECK: saved my_pid 5911 in check mode.
[2015/03/08 19:52:11 5911] RAID MODE: 1, sn=
[2015/03/08 19:52:11 5911] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2015/03/08 19:52:11 5911] Current file system status: ext4
[2015/03/08 19:52:11 5911] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2015/03/08 19:52:12 5911] Running disk SMART quick self-test on new disk 4 [/dev/sdd]...
[2015/03/08 19:54:12 5911] PASSED
[2015/03/08 19:54:12 5911] LINE 1144: exec command: killall -HUP monitor_enclosure
[2015/03/08 19:54:13 5911] X_level: 6
[2015/03/08 19:54:13 5911] /usr/sbin/expand_md -a super
[2015/03/08 19:54:13 5911] MD degraded 1, bg_job 0, boot 0
[2015/03/08 19:54:13 5911] STAGE_WIPE: Clean my_pid 5911
[2015/03/27 18:34:37 2109] Boot, handle mutiple expand_md
[2015/03/27 18:34:38 2110] STAGE_CHECK: saved my_pid 2110 in check mode.
[2015/03/27 18:34:38 2110] RAID MODE: 1, sn=
[2015/03/27 18:34:38 2110] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2015/03/27 18:34:38 2110] Current file system status: offline
[2015/03/27 18:34:38 2110] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2015/03/27 18:34:38 2110] Running disk SMART quick self-test on new disk 4 [/dev/sdd]...
[2015/03/27 18:36:49 2110] PASSED
[2015/03/27 18:36:49 2110] LINE 1144: exec command: killall -HUP monitor_enclosure
[2015/03/27 18:36:50 2110] X_level: 6
[2015/03/27 18:36:50 2110] /usr/sbin/expand_md
[2015/03/27 18:36:50 2110] MD degraded 1, bg_job 0, boot 1
[2015/03/27 18:36:50 2110] Read 1957072 byte from configuration
[2015/03/27 18:36:50 2110] Disk configuration matching with online configuration.
[2015/03/27 18:36:50 2110] May need to fix array.
[2015/03/27 18:36:50 2110] new_disk_pt_count: 1
[2015/03/27 18:36:50 2110] * new disk: /dev/sdd
[2015/03/27 18:36:50 2110] ===== Partition Entry (MD not used) =====
[2015/03/27 18:36:50 2110] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 0 0 NO_MD 0
[2015/03/27 18:36:50 2110] partitions: 0 property: UNKNOWN
[2015/03/27 18:36:50 2110] ===== Partition Entry (Used by MD) =====
[2015/03/27 18:36:50 2110] 000 /dev/sda,WD-WCAWZ1982796,8, 0, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/27 18:36:50 2110] partitions: 3 property: 4K
[2015/03/27 18:36:50 2110] 000 /dev/sda1, 8, 1, 4194304 MD_FULL md=/dev/md0
[2015/03/27 18:36:50 2110] 001 /dev/sda2, 8, 2, 524288 MD_FULL md=/dev/md1
[2015/03/27 18:36:50 2110] 002 /dev/sda3, 8, 3, 2925545912 MD_FULL md=/dev/md2
[2015/03/27 18:36:50 2110] 001 /dev/sdb,WD-WCAWZ2042830,8, 16, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/27 18:36:50 2110] 000 /dev/sdb1, 8, 17, 4194304 MD_FULL md=/dev/md0
[2015/03/27 18:36:50 2110] 001 /dev/sdb2, 8, 18, 524288 MD_FULL md=/dev/md1
[2015/03/27 18:36:50 2110] 002 /dev/sdb3, 8, 19, 2925545912 MD_FULL md=/dev/md2
[2015/03/27 18:36:50 2110] 002 /dev/sdc,WD-WCAWZ2059262,8, 32, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/27 18:36:50 2110] 000 /dev/sdc1, 8, 33, 4194304 MD_FULL md=/dev/md0
[2015/03/27 18:36:50 2110] 001 /dev/sdc2, 8, 34, 524288 MD_FULL md=/dev/md1
[2015/03/27 18:36:50 2110] 002 /dev/sdc3, 8, 35, 2925545912 MD_FULL md=/dev/md2
[2015/03/27 18:36:50 2110] 003 /dev/sde,WD-WCAWZ2059507,8, 64, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/27 18:36:50 2110] 000 /dev/sde1, 8, 65, 4194304 MD_FULL md=/dev/md0
[2015/03/27 18:36:50 2110] 001 /dev/sde2, 8, 66, 524288 MD_FULL md=/dev/md1
[2015/03/27 18:36:50 2110] 002 /dev/sde3, 8, 67, 2925545912 MD_FULL md=/dev/md2
[2015/03/27 18:36:50 2110] 004 /dev/sdf,WD-WCAWZ2042889,8, 80, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/27 18:36:50 2110] 000 /dev/sdf1, 8, 81, 4194304 MD_FULL md=/dev/md0
[2015/03/27 18:36:50 2110] 001 /dev/sdf2, 8, 82, 524288 MD_FULL md=/dev/md1
[2015/03/27 18:36:50 2110] 002 /dev/sdf3, 8, 83, 2925545912 MD_FULL md=/dev/md2
[2015/03/27 18:36:50 2110] in find_drive_... looking at /dev/md2
[2015/03/27 18:36:50 2110] found drive has the needed size for /dev/md2: /dev/sdf, 2930266584, 2930264504
[2015/03/27 18:36:50 2110] Drive sn WD-WCAWZ1982796
[2015/03/27 18:36:50 2110] Drive sn WD-WCAWZ1982796 WD-WCAWZ1982796
[2015/03/27 18:36:50 2110] Take /dev/sda WD-WCAWZ1982796 away
[2015/03/27 18:36:50 2110] Drive sn WD-WCAWZ2042830
[2015/03/27 18:36:50 2110] Drive sn WD-WCAWZ2042830 WD-WCAWZ2042830
[2015/03/27 18:36:50 2110] Take /dev/sdb WD-WCAWZ2042830 away
[2015/03/27 18:36:50 2110] Drive sn WD-WCAWZ2059262
[2015/03/27 18:36:50 2110] Drive sn WD-WCAWZ2059262 WD-WCAWZ2059262
[2015/03/27 18:36:50 2110] Take /dev/sdc WD-WCAWZ2059262 away
[2015/03/27 18:36:50 2110] Drive sn WD-WCAWZ1978251
[2015/03/27 18:36:50 2110] Drive WD-WCAWZ1978251 missing.
[2015/03/27 18:36:50 2110] Drive sn WD-WCAWZ2059507
[2015/03/27 18:36:50 2110] Drive sn WD-WCAWZ2059507 WD-WCAWZ2059507
[2015/03/27 18:36:50 2110] Take /dev/sde WD-WCAWZ2059507 away
[2015/03/27 18:36:50 2110] Drive sn WD-WCAWZ2042889
[2015/03/27 18:36:50 2110] Drive sn WD-WCAWZ2042889 WD-WCAWZ2042889
[2015/03/27 18:36:50 2110] Take /dev/sdf WD-WCAWZ2042889 away
[2015/03/27 18:36:50 2110] Total missing: 1, index=3
[2015/03/27 18:36:50 2110] found missing drive: /dev/sdd WD-WCAWZ1978251 MD_NULL blocks=2930266584 2930264504 2930264504
[2015/03/27 18:36:50 2110] XRAID cfg_pt = WD-WCAWZ2042889, these two drives size close: 0 /dev/sdd 2930266584, 0 /dev/sda 2930266584
[2015/03/27 18:36:50 2110] Changed drive selction: s=4/0, t=0/0, file=/var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
[2015/03/27 18:36:51 2110] Repair md: use disk /dev/sdd, size 2930266584
[2015/03/27 18:36:54 2110] LINE 1505: exec command: sgdisk -Z /dev/sdd
Found valid GPT with corrupt MBR; using GPT and will write new
protective MBR on save.
other utilities.
[2015/03/27 18:36:57 2110] Update new added disk information: from /dev/sdf to /dev/sdd
[2015/03/27 18:36:57 2110] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 0 0 NO_MD 0
[2015/03/27 18:36:57 2110] partitions: 0 property: UNKNOWN
[2015/03/27 18:36:57 2110] 000 /dev/sdf,WD-WCAWZ2042889,8, 80, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/27 18:36:57 2110] partitions: 3 property: 4K
[2015/03/27 18:36:57 2110] 000 /dev/sdf1, 8, 81, 4194304 MD_FULL md=/dev/md0
[2015/03/27 18:36:57 2110] 001 /dev/sdf2, 8, 82, 524288 MD_FULL md=/dev/md1
[2015/03/27 18:36:57 2110] 002 /dev/sdf3, 8, 83, 2925545912 MD_FULL md=/dev/md2
[2015/03/27 18:36:57 2110] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 2930264504 2930264504 NO_MD 0
[2015/03/27 18:36:57 2110] partitions: 3 property: UNKNOWN
[2015/03/27 18:36:57 2110] 000 /dev/sdd1, 0, 0, 4194304 NO_MD md=
[2015/03/27 18:36:57 2110] 001 /dev/sdd2, 0, 0, 524288 NO_MD md=
[2015/03/27 18:36:57 2110] 002 /dev/sdd3, 0, 0, 2925545912 NO_MD md=
[2015/03/27 18:36:57 2110] Get format of pt /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
[2015/03/27 18:36:57 2110] Error unkonwn partition table /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889 !!!!
[2015/03/27 18:36:57 2110] Need to increase ext size from 0 to 0
[2015/03/27 18:36:57 2110] LINE 3717: exec command: sfdisk --force -L /dev/sdd < /var/log/frontview/.V_E.source_pt1.sav
Old situation:
No partitions found
New situation:
No partitions found
[2015/03/27 18:36:58 2110] Input target disk 4K align partition problem: 256, use old partition.
[2015/03/27 18:36:58 2110] LINE 3723: exec command: sfdisk --force -L /dev/sdd < /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
Old situation:
No partitions found
New situation:
No partitions found
[2015/03/27 18:36:58 2110] LINE 3730: exec command: sgdisk -g -a 8 /dev/sdd
[2015/03/27 18:37:02 2110] Succeed to convert mbr to gpt /dev/sda.
[2015/03/27 18:37:02 2110] Input target disk partition problem: 256
[2015/03/27 18:37:02 2110] Failed to add disk to md
[2015/03/27 18:37:02 2110] Added drive to md, grown=0/0xffa72fb8
[2015/03/27 18:37:02 2110] LINE 4852: exec command: /usr/sbin/expand_md -a super >> /var/log/frontview/expand_md.log 2>&1 &
[2015/03/27 18:37:02 2110] LINE 4855: exec command: /frontview/bin/volumescan &
[2015/03/27 18:37:03 2110] LINE 4939: exec command: ps -ef | grep expand_md | grep -v grep > /var/log/frontview/.V_E.snapshotstat
[2015/03/27 18:37:03 2110] STAGE_WIPE: Clean my_pid 2110
[2015/03/27 18:38:04 6023] STAGE_CHECK: saved my_pid 6023 in check mode.
[2015/03/27 18:38:04 6023] RAID MODE: 1, sn=
[2015/03/27 18:38:04 6023] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2015/03/27 18:38:04 6023] Current file system status: ext4
[2015/03/27 18:38:04 6023] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2015/03/27 18:38:04 6023] Running disk SMART quick self-test on new disk 4 [/dev/sdd]...
[2015/03/27 18:40:11 6023] PASSED
[2015/03/27 18:40:11 6023] LINE 1144: exec command: killall -HUP monitor_enclosure
[2015/03/27 18:40:11 6023] X_level: 6
[2015/03/27 18:40:11 6023] /usr/sbin/expand_md -a super
[2015/03/27 18:40:11 6023] MD degraded 1, bg_job 0, boot 0
[2015/03/27 18:40:11 6023] STAGE_WIPE: Clean my_pid 6023
[2015/03/27 18:44:21 2100] Boot, handle mutiple expand_md
[2015/03/27 18:44:22 2101] STAGE_CHECK: saved my_pid 2101 in check mode.
[2015/03/27 18:44:22 2101] RAID MODE: 1, sn=
[2015/03/27 18:44:23 2101] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2015/03/27 18:44:23 2101] Current file system status: offline
[2015/03/27 18:44:23 2101] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2015/03/27 18:44:23 2101] Running disk SMART quick self-test on new disk 4 [/dev/sdd]...
[2015/03/27 18:46:34 2101] PASSED
[2015/03/27 18:46:34 2101] LINE 1144: exec command: killall -HUP monitor_enclosure
[2015/03/27 18:46:35 2101] /usr/sbin/expand_md
[2015/03/27 18:46:35 2101] Background job on, degraded on, find new disks, wait...
[2015/03/27 18:50:35 2101] X_level: 6
[2015/03/27 18:50:35 2101] MD degraded 1, bg_job 0, boot 1
[2015/03/27 18:50:35 2101] Read 1957072 byte from configuration
[2015/03/27 18:50:35 2101] Disk configuration matching with online configuration.
[2015/03/27 18:50:35 2101] May need to fix array.
[2015/03/27 18:50:35 2101] new_disk_pt_count: 1
[2015/03/27 18:50:35 2101] * new disk: /dev/sdd
[2015/03/27 18:50:35 2101] ===== Partition Entry (MD not used) =====
[2015/03/27 18:50:35 2101] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 0 0 NO_MD 0
[2015/03/27 18:50:35 2101] partitions: 0 property: UNKNOWN
[2015/03/27 18:50:35 2101] ===== Partition Entry (Used by MD) =====
[2015/03/27 18:50:35 2101] 000 /dev/sda,WD-WCAWZ1982796,8, 0, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/27 18:50:35 2101] partitions: 3 property: 4K
[2015/03/27 18:50:35 2101] 000 /dev/sda1, 8, 1, 4194304 MD_FULL md=/dev/md0
[2015/03/27 18:50:35 2101] 001 /dev/sda2, 8, 2, 524288 MD_FULL md=/dev/md1
[2015/03/27 18:50:35 2101] 002 /dev/sda3, 8, 3, 2925545912 MD_FULL md=/dev/md2
[2015/03/27 18:50:35 2101] 001 /dev/sdb,WD-WCAWZ2042830,8, 16, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/27 18:50:35 2101] 000 /dev/sdb1, 8, 17, 4194304 MD_FULL md=/dev/md0
[2015/03/27 18:50:35 2101] 001 /dev/sdb2, 8, 18, 524288 MD_FULL md=/dev/md1
[2015/03/27 18:50:35 2101] 002 /dev/sdb3, 8, 19, 2925545912 MD_FULL md=/dev/md2
[2015/03/27 18:50:35 2101] 002 /dev/sdc,WD-WCAWZ2059262,8, 32, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/27 18:50:35 2101] 000 /dev/sdc1, 8, 33, 4194304 MD_FULL md=/dev/md0
[2015/03/27 18:50:35 2101] 001 /dev/sdc2, 8, 34, 524288 MD_FULL md=/dev/md1
[2015/03/27 18:50:35 2101] 002 /dev/sdc3, 8, 35, 2925545912 MD_FULL md=/dev/md2
[2015/03/27 18:50:35 2101] 003 /dev/sde,WD-WCAWZ2059507,8, 64, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/27 18:50:35 2101] 000 /dev/sde1, 8, 65, 4194304 MD_FULL md=/dev/md0
[2015/03/27 18:50:35 2101] 001 /dev/sde2, 8, 66, 524288 MD_FULL md=/dev/md1
[2015/03/27 18:50:35 2101] 002 /dev/sde3, 8, 67, 2925545912 MD_FULL md=/dev/md2
[2015/03/27 18:50:35 2101] 004 /dev/sdf,WD-WCAWZ2042889,8, 80, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/27 18:50:35 2101] 000 /dev/sdf1, 8, 81, 4194304 MD_FULL md=/dev/md0
[2015/03/27 18:50:35 2101] 001 /dev/sdf2, 8, 82, 524288 MD_FULL md=/dev/md1
[2015/03/27 18:50:35 2101] 002 /dev/sdf3, 8, 83, 2925545912 MD_FULL md=/dev/md2
[2015/03/27 18:50:35 2101] in find_drive_... looking at /dev/md2
[2015/03/27 18:50:35 2101] found drive has the needed size for /dev/md2: /dev/sdf, 2930266584, 2930264504
[2015/03/27 18:50:35 2101] Drive sn WD-WCAWZ1982796
[2015/03/27 18:50:35 2101] Drive sn WD-WCAWZ1982796 WD-WCAWZ1982796
[2015/03/27 18:50:35 2101] Take /dev/sda WD-WCAWZ1982796 away
[2015/03/27 18:50:35 2101] Drive sn WD-WCAWZ2042830
[2015/03/27 18:50:35 2101] Drive sn WD-WCAWZ2042830 WD-WCAWZ2042830
[2015/03/27 18:50:35 2101] Take /dev/sdb WD-WCAWZ2042830 away
[2015/03/27 18:50:35 2101] Drive sn WD-WCAWZ2059262
[2015/03/27 18:50:35 2101] Drive sn WD-WCAWZ2059262 WD-WCAWZ2059262
[2015/03/27 18:50:35 2101] Take /dev/sdc WD-WCAWZ2059262 away
[2015/03/27 18:50:35 2101] Drive sn WD-WCAWZ1978251
[2015/03/27 18:50:35 2101] Drive WD-WCAWZ1978251 missing.
[2015/03/27 18:50:35 2101] Drive sn WD-WCAWZ2059507
[2015/03/27 18:50:35 2101] Drive sn WD-WCAWZ2059507 WD-WCAWZ2059507
[2015/03/27 18:50:35 2101] Take /dev/sde WD-WCAWZ2059507 away
[2015/03/27 18:50:35 2101] Drive sn WD-WCAWZ2042889
[2015/03/27 18:50:35 2101] Drive sn WD-WCAWZ2042889 WD-WCAWZ2042889
[2015/03/27 18:50:35 2101] Take /dev/sdf WD-WCAWZ2042889 away
[2015/03/27 18:50:35 2101] Total missing: 1, index=3
[2015/03/27 18:50:35 2101] found missing drive: /dev/sdd WD-WCAWZ1978251 MD_NULL blocks=2930266584 2930264504 2930264504
[2015/03/27 18:50:35 2101] XRAID cfg_pt = WD-WCAWZ2042889, these two drives size close: 0 /dev/sdd 2930266584, 0 /dev/sda 2930266584
[2015/03/27 18:50:35 2101] Changed drive selction: s=4/0, t=0/0, file=/var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
[2015/03/27 18:50:35 2101] Repair md: use disk /dev/sdd, size 2930266584
[2015/03/27 18:50:39 2101] LINE 1505: exec command: sgdisk -Z /dev/sdd
other utilities.
[2015/03/27 18:50:42 2101] Update new added disk information: from /dev/sdf to /dev/sdd
[2015/03/27 18:50:42 2101] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 0 0 NO_MD 0
[2015/03/27 18:50:42 2101] partitions: 0 property: UNKNOWN
[2015/03/27 18:50:42 2101] 000 /dev/sdf,WD-WCAWZ2042889,8, 80, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/03/27 18:50:42 2101] partitions: 3 property: 4K
[2015/03/27 18:50:42 2101] 000 /dev/sdf1, 8, 81, 4194304 MD_FULL md=/dev/md0
[2015/03/27 18:50:42 2101] 001 /dev/sdf2, 8, 82, 524288 MD_FULL md=/dev/md1
[2015/03/27 18:50:42 2101] 002 /dev/sdf3, 8, 83, 2925545912 MD_FULL md=/dev/md2
[2015/03/27 18:50:42 2101] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 2930264504 2930264504 NO_MD 0
[2015/03/27 18:50:42 2101] partitions: 3 property: UNKNOWN
[2015/03/27 18:50:42 2101] 000 /dev/sdd1, 0, 0, 4194304 NO_MD md=
[2015/03/27 18:50:42 2101] 001 /dev/sdd2, 0, 0, 524288 NO_MD md=
[2015/03/27 18:50:42 2101] 002 /dev/sdd3, 0, 0, 2925545912 NO_MD md=
[2015/03/27 18:50:42 2101] Get format of pt /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
[2015/03/27 18:50:42 2101] Error unkonwn partition table /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889 !!!!
[2015/03/27 18:50:42 2101] Need to increase ext size from 0 to 0
[2015/03/27 18:50:42 2101] LINE 3717: exec command: sfdisk --force -L /dev/sdd < /var/log/frontview/.V_E.source_pt1.sav
Old situation:
No partitions found
New situation:
No partitions found
[2015/03/27 18:50:43 2101] Input target disk 4K align partition problem: 256, use old partition.
[2015/03/27 18:50:43 2101] LINE 3723: exec command: sfdisk --force -L /dev/sdd < /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
Old situation:
No partitions found
New situation:
No partitions found
[2015/03/27 18:50:43 2101] LINE 3730: exec command: sgdisk -g -a 8 /dev/sdd
[2015/03/27 18:50:45 2101] Succeed to convert mbr to gpt /dev/sda.
[2015/03/27 18:50:45 2101] Input target disk partition problem: 256
[2015/03/27 18:50:45 2101] Failed to add disk to md
[2015/03/27 18:50:45 2101] Added drive to md, grown=0/0xfffbe808
[2015/03/27 18:50:45 2101] LINE 4852: exec command: /usr/sbin/expand_md -a super >> /var/log/frontview/expand_md.log 2>&1 &
[2015/03/27 18:50:46 2101] LINE 4855: exec command: /frontview/bin/volumescan &
[2015/03/27 18:50:46 2101] LINE 4939: exec command: ps -ef | grep expand_md | grep -v grep > /var/log/frontview/.V_E.snapshotstat
[2015/03/27 18:50:46 2101] STAGE_WIPE: Clean my_pid 2101
[2015/03/27 18:50:46 13976] STAGE_CHECK: saved my_pid 13976 in check mode.
[2015/03/27 18:50:46 13976] RAID MODE: 1, sn=
[2015/03/27 18:50:47 13976] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2015/03/27 18:50:47 13976] Current file system status: ext4
[2015/03/27 18:50:47 13976] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2015/03/27 18:50:47 13976] Running disk SMART quick self-test on new disk 4 [/dev/sdd]...
[2015/03/27 18:52:47 13976] PASSED
[2015/03/27 18:52:48 13976] LINE 1144: exec command: killall -HUP monitor_enclosure
[2015/03/27 18:52:49 13976] X_level: 6
[2015/03/27 18:52:49 13976] /usr/sbin/expand_md -a super
[2015/03/27 18:52:49 13976] MD degraded 1, bg_job 0, boot 0
[2015/03/27 18:52:49 13976] STAGE_WIPE: Clean my_pid 13976
[2015/04/04 17:35:43 2113] Boot, handle mutiple expand_md
[2015/04/04 17:35:44 2114] STAGE_CHECK: saved my_pid 2114 in check mode.
[2015/04/04 17:35:44 2114] RAID MODE: 1, sn=
[2015/04/04 17:35:44 2114] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2015/04/04 17:35:44 2114] Current file system status: offline
[2015/04/04 17:35:44 2114] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2015/04/04 17:35:45 2114] Running disk SMART quick self-test on new disk 4 [/dev/sdd]...
[2015/04/04 17:37:45 2114] PASSED
[2015/04/04 17:37:45 2114] LINE 1144: exec command: killall -HUP monitor_enclosure
[2015/04/04 17:37:46 2114] X_level: 6
[2015/04/04 17:37:46 2114] /usr/sbin/expand_md
[2015/04/04 17:37:46 2114] MD degraded 1, bg_job 0, boot 1
[2015/04/04 17:37:46 2114] Read 1957072 byte from configuration
[2015/04/04 17:37:46 2114] Disk configuration matching with online configuration.
[2015/04/04 17:37:46 2114] May need to fix array.
[2015/04/04 17:37:46 2114] new_disk_pt_count: 1
[2015/04/04 17:37:46 2114] * new disk: /dev/sdd
[2015/04/04 17:37:46 2114] ===== Partition Entry (MD not used) =====
[2015/04/04 17:37:46 2114] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 0 0 NO_MD 0
[2015/04/04 17:37:46 2114] partitions: 0 property: UNKNOWN
[2015/04/04 17:37:46 2114] ===== Partition Entry (Used by MD) =====
[2015/04/04 17:37:46 2114] 000 /dev/sda,WD-WCAWZ1982796,8, 0, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/04 17:37:46 2114] partitions: 3 property: 4K
[2015/04/04 17:37:46 2114] 000 /dev/sda1, 8, 1, 4194304 MD_FULL md=/dev/md0
[2015/04/04 17:37:46 2114] 001 /dev/sda2, 8, 2, 524288 MD_FULL md=/dev/md1
[2015/04/04 17:37:46 2114] 002 /dev/sda3, 8, 3, 2925545912 MD_FULL md=/dev/md2
[2015/04/04 17:37:46 2114] 001 /dev/sdb,WD-WCAWZ2042830,8, 16, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/04 17:37:46 2114] 000 /dev/sdb1, 8, 17, 4194304 MD_FULL md=/dev/md0
[2015/04/04 17:37:46 2114] 001 /dev/sdb2, 8, 18, 524288 MD_FULL md=/dev/md1
[2015/04/04 17:37:46 2114] 002 /dev/sdb3, 8, 19, 2925545912 MD_FULL md=/dev/md2
[2015/04/04 17:37:46 2114] 002 /dev/sdc,WD-WCAWZ2059262,8, 32, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/04 17:37:46 2114] 000 /dev/sdc1, 8, 33, 4194304 MD_FULL md=/dev/md0
[2015/04/04 17:37:46 2114] 001 /dev/sdc2, 8, 34, 524288 MD_FULL md=/dev/md1
[2015/04/04 17:37:46 2114] 002 /dev/sdc3, 8, 35, 2925545912 MD_FULL md=/dev/md2
[2015/04/04 17:37:46 2114] 003 /dev/sde,WD-WCAWZ2059507,8, 64, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/04 17:37:46 2114] 000 /dev/sde1, 8, 65, 4194304 MD_FULL md=/dev/md0
[2015/04/04 17:37:46 2114] 001 /dev/sde2, 8, 66, 524288 MD_FULL md=/dev/md1
[2015/04/04 17:37:46 2114] 002 /dev/sde3, 8, 67, 2925545912 MD_FULL md=/dev/md2
[2015/04/04 17:37:46 2114] 004 /dev/sdf,WD-WCAWZ2042889,8, 80, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/04 17:37:46 2114] 000 /dev/sdf1, 8, 81, 4194304 MD_FULL md=/dev/md0
[2015/04/04 17:37:46 2114] 001 /dev/sdf2, 8, 82, 524288 MD_FULL md=/dev/md1
[2015/04/04 17:37:46 2114] 002 /dev/sdf3, 8, 83, 2925545912 MD_FULL md=/dev/md2
[2015/04/04 17:37:46 2114] in find_drive_... looking at /dev/md2
[2015/04/04 17:37:46 2114] found drive has the needed size for /dev/md2: /dev/sdf, 2930266584, 2930264504
[2015/04/04 17:37:46 2114] Drive sn WD-WCAWZ1982796
[2015/04/04 17:37:46 2114] Drive sn WD-WCAWZ1982796 WD-WCAWZ1982796
[2015/04/04 17:37:46 2114] Take /dev/sda WD-WCAWZ1982796 away
[2015/04/04 17:37:46 2114] Drive sn WD-WCAWZ2042830
[2015/04/04 17:37:46 2114] Drive sn WD-WCAWZ2042830 WD-WCAWZ2042830
[2015/04/04 17:37:46 2114] Take /dev/sdb WD-WCAWZ2042830 away
[2015/04/04 17:37:46 2114] Drive sn WD-WCAWZ2059262
[2015/04/04 17:37:46 2114] Drive sn WD-WCAWZ2059262 WD-WCAWZ2059262
[2015/04/04 17:37:46 2114] Take /dev/sdc WD-WCAWZ2059262 away
[2015/04/04 17:37:46 2114] Drive sn WD-WCAWZ1978251
[2015/04/04 17:37:46 2114] Drive WD-WCAWZ1978251 missing.
[2015/04/04 17:37:46 2114] Drive sn WD-WCAWZ2059507
[2015/04/04 17:37:46 2114] Drive sn WD-WCAWZ2059507 WD-WCAWZ2059507
[2015/04/04 17:37:46 2114] Take /dev/sde WD-WCAWZ2059507 away
[2015/04/04 17:37:46 2114] Drive sn WD-WCAWZ2042889
[2015/04/04 17:37:46 2114] Drive sn WD-WCAWZ2042889 WD-WCAWZ2042889
[2015/04/04 17:37:46 2114] Take /dev/sdf WD-WCAWZ2042889 away
[2015/04/04 17:37:46 2114] Total missing: 1, index=3
[2015/04/04 17:37:46 2114] found missing drive: /dev/sdd WD-WCAWZ1978251 MD_NULL blocks=2930266584 2930264504 2930264504
[2015/04/04 17:37:46 2114] XRAID cfg_pt = WD-WCAWZ2042889, these two drives size close: 0 /dev/sdd 2930266584, 0 /dev/sda 2930266584
[2015/04/04 17:37:46 2114] Changed drive selction: s=4/0, t=0/0, file=/var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
[2015/04/04 17:37:47 2114] Repair md: use disk /dev/sdd, size 2930266584
[2015/04/04 17:37:50 2114] LINE 1505: exec command: sgdisk -Z /dev/sdd
other utilities.
[2015/04/04 17:37:54 2114] Update new added disk information: from /dev/sdf to /dev/sdd
[2015/04/04 17:37:54 2114] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 0 0 NO_MD 0
[2015/04/04 17:37:54 2114] partitions: 0 property: UNKNOWN
[2015/04/04 17:37:54 2114] 000 /dev/sdf,WD-WCAWZ2042889,8, 80, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/04 17:37:54 2114] partitions: 3 property: 4K
[2015/04/04 17:37:54 2114] 000 /dev/sdf1, 8, 81, 4194304 MD_FULL md=/dev/md0
[2015/04/04 17:37:54 2114] 001 /dev/sdf2, 8, 82, 524288 MD_FULL md=/dev/md1
[2015/04/04 17:37:54 2114] 002 /dev/sdf3, 8, 83, 2925545912 MD_FULL md=/dev/md2
[2015/04/04 17:37:54 2114] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 2930264504 2930264504 NO_MD 0
[2015/04/04 17:37:54 2114] partitions: 3 property: UNKNOWN
[2015/04/04 17:37:54 2114] 000 /dev/sdd1, 0, 0, 4194304 NO_MD md=
[2015/04/04 17:37:54 2114] 001 /dev/sdd2, 0, 0, 524288 NO_MD md=
[2015/04/04 17:37:54 2114] 002 /dev/sdd3, 0, 0, 2925545912 NO_MD md=
[2015/04/04 17:37:54 2114] Get format of pt /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
[2015/04/04 17:37:54 2114] Error unkonwn partition table /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889 !!!!
[2015/04/04 17:37:54 2114] Need to increase ext size from 0 to 0
[2015/04/04 17:37:54 2114] LINE 3717: exec command: sfdisk --force -L /dev/sdd < /var/log/frontview/.V_E.source_pt1.sav
Old situation:
No partitions found
New situation:
No partitions found
[2015/04/04 17:37:54 2114] Input target disk 4K align partition problem: 256, use old partition.
[2015/04/04 17:37:54 2114] LINE 3723: exec command: sfdisk --force -L /dev/sdd < /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
Old situation:
No partitions found
New situation:
No partitions found
[2015/04/04 17:37:54 2114] LINE 3730: exec command: sgdisk -g -a 8 /dev/sdd
[2015/04/04 17:37:58 2114] Succeed to convert mbr to gpt /dev/sda.
[2015/04/04 17:37:58 2114] Input target disk partition problem: 256
[2015/04/04 17:37:58 2114] Failed to add disk to md
[2015/04/04 17:37:58 2114] Added drive to md, grown=0/0xff803358
[2015/04/04 17:37:58 2114] LINE 4852: exec command: /usr/sbin/expand_md -a super >> /var/log/frontview/expand_md.log 2>&1 &
[2015/04/04 17:37:58 2114] LINE 4855: exec command: /frontview/bin/volumescan &
[2015/04/04 17:37:58 2114] LINE 4939: exec command: ps -ef | grep expand_md | grep -v grep > /var/log/frontview/.V_E.snapshotstat
[2015/04/04 17:37:59 2114] STAGE_WIPE: Clean my_pid 2114
[2015/04/04 17:37:59 5957] STAGE_CHECK: saved my_pid 5957 in check mode.
[2015/04/04 17:37:59 5957] RAID MODE: 1, sn=
[2015/04/04 17:37:59 5957] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2015/04/04 17:37:59 5957] Current file system status: ext4
[2015/04/04 17:37:59 5957] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2015/04/04 17:37:59 5957] Running disk SMART quick self-test on new disk 4 [/dev/sdd]...
[2015/04/04 17:40:00 5957] PASSED
[2015/04/04 17:40:00 5957] LINE 1144: exec command: killall -HUP monitor_enclosure
[2015/04/04 17:40:00 5957] X_level: 6
[2015/04/04 17:40:00 5957] /usr/sbin/expand_md -a super
[2015/04/04 17:40:00 5957] MD degraded 1, bg_job 0, boot 0
[2015/04/04 17:40:00 5957] STAGE_WIPE: Clean my_pid 5957
Sat Apr 4 19:38:16 NZDT 2015
[2015/04/04 19:38:17 1192] STAGE_CHECK: saved my_pid 1192 in check mode.
[2015/04/04 19:38:17 1192] RAID MODE: 1, sn=
[2015/04/04 19:38:18 1192] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2015/04/04 19:38:18 1192] Current file system status: ext4
[2015/04/04 19:38:18 1192] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2015/04/04 19:38:18 1192] Running disk SMART quick self-test on new disk 4 [/dev/sdd]...
[2015/04/04 19:40:18 1192] PASSED
[2015/04/04 19:40:19 1192] LINE 1144: exec command: killall -HUP monitor_enclosure
[2015/04/04 19:40:20 1192] X_level: 6
[2015/04/04 19:40:20 1192] /usr/sbin/expand_md
[2015/04/04 19:40:20 1192] MD degraded 1, bg_job 0, boot 0
[2015/04/04 19:40:20 1192] Read 1957072 byte from configuration
[2015/04/04 19:40:20 1192] Disk configuration matching with online configuration.
[2015/04/04 19:40:20 1192] May need to fix array.
[2015/04/04 19:40:20 1192] new_disk_pt_count: 1
[2015/04/04 19:40:20 1192] * new disk: /dev/sdd
[2015/04/04 19:40:20 1192] ===== Partition Entry (MD not used) =====
[2015/04/04 19:40:20 1192] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 4718592 4718592 NO_MD 0
[2015/04/04 19:40:20 1192] partitions: 2 property: 4K
[2015/04/04 19:40:20 1192] 000 /dev/sdd1, 8, 49, 4194304 NO_MD md=
[2015/04/04 19:40:20 1192] 001 /dev/sdd2, 8, 50, 524288 NO_MD md=
[2015/04/04 19:40:20 1192] ===== Partition Entry (Used by MD) =====
[2015/04/04 19:40:20 1192] 000 /dev/sda,WD-WCAWZ1982796,8, 0, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/04 19:40:20 1192] partitions: 3 property: 4K
[2015/04/04 19:40:20 1192] 000 /dev/sda1, 8, 1, 4194304 MD_FULL md=/dev/md0
[2015/04/04 19:40:20 1192] 001 /dev/sda2, 8, 2, 524288 MD_FULL md=/dev/md1
[2015/04/04 19:40:20 1192] 002 /dev/sda3, 8, 3, 2925545912 MD_FULL md=/dev/md2
[2015/04/04 19:40:20 1192] 001 /dev/sdb,WD-WCAWZ2042830,8, 16, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/04 19:40:20 1192] 000 /dev/sdb1, 8, 17, 4194304 MD_FULL md=/dev/md0
[2015/04/04 19:40:20 1192] 001 /dev/sdb2, 8, 18, 524288 MD_FULL md=/dev/md1
[2015/04/04 19:40:20 1192] 002 /dev/sdb3, 8, 19, 2925545912 MD_FULL md=/dev/md2
[2015/04/04 19:40:20 1192] 002 /dev/sdc,WD-WCAWZ2059262,8, 32, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/04 19:40:20 1192] 000 /dev/sdc1, 8, 33, 4194304 MD_FULL md=/dev/md0
[2015/04/04 19:40:20 1192] 001 /dev/sdc2, 8, 34, 524288 MD_FULL md=/dev/md1
[2015/04/04 19:40:20 1192] 002 /dev/sdc3, 8, 35, 2925545912 MD_FULL md=/dev/md2
[2015/04/04 19:40:20 1192] 003 /dev/sde,WD-WCAWZ2059507,8, 64, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/04 19:40:20 1192] 000 /dev/sde1, 8, 65, 4194304 MD_FULL md=/dev/md0
[2015/04/04 19:40:20 1192] 001 /dev/sde2, 8, 66, 524288 MD_FULL md=/dev/md1
[2015/04/04 19:40:20 1192] 002 /dev/sde3, 8, 67, 2925545912 MD_FULL md=/dev/md2
[2015/04/04 19:40:20 1192] 004 /dev/sdf,WD-WCAWZ2042889,8, 80, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/04 19:40:20 1192] 000 /dev/sdf1, 8, 81, 4194304 MD_FULL md=/dev/md0
[2015/04/04 19:40:20 1192] 001 /dev/sdf2, 8, 82, 524288 MD_FULL md=/dev/md1
[2015/04/04 19:40:20 1192] 002 /dev/sdf3, 8, 83, 2925545912 MD_FULL md=/dev/md2
[2015/04/04 19:40:20 1192] in find_drive_... looking at /dev/md2
[2015/04/04 19:40:20 1192] found drive has the needed size for /dev/md2: /dev/sdf, 2930266584, 2930264504
[2015/04/04 19:40:20 1192] Drive sn WD-WCAWZ1982796
[2015/04/04 19:40:20 1192] Drive sn WD-WCAWZ1982796 WD-WCAWZ1982796
[2015/04/04 19:40:20 1192] Take /dev/sda WD-WCAWZ1982796 away
[2015/04/04 19:40:20 1192] Drive sn WD-WCAWZ2042830
[2015/04/04 19:40:20 1192] Drive sn WD-WCAWZ2042830 WD-WCAWZ2042830
[2015/04/04 19:40:20 1192] Take /dev/sdb WD-WCAWZ2042830 away
[2015/04/04 19:40:20 1192] Drive sn WD-WCAWZ2059262
[2015/04/04 19:40:20 1192] Drive sn WD-WCAWZ2059262 WD-WCAWZ2059262
[2015/04/04 19:40:20 1192] Take /dev/sdc WD-WCAWZ2059262 away
[2015/04/04 19:40:20 1192] Drive sn WD-WCAWZ1978251
[2015/04/04 19:40:20 1192] Drive WD-WCAWZ1978251 missing.
[2015/04/04 19:40:20 1192] Drive sn WD-WCAWZ2059507
[2015/04/04 19:40:20 1192] Drive sn WD-WCAWZ2059507 WD-WCAWZ2059507
[2015/04/04 19:40:20 1192] Take /dev/sde WD-WCAWZ2059507 away
[2015/04/04 19:40:20 1192] Drive sn WD-WCAWZ2042889
[2015/04/04 19:40:20 1192] Drive sn WD-WCAWZ2042889 WD-WCAWZ2042889
[2015/04/04 19:40:20 1192] Take /dev/sdf WD-WCAWZ2042889 away
[2015/04/04 19:40:20 1192] Total missing: 1, index=3
[2015/04/04 19:40:20 1192] found missing drive: /dev/sdd WD-WCAWZ1978251 MD_NULL blocks=2930266584 2930264504 2930264504
[2015/04/04 19:40:20 1192] XRAID cfg_pt = WD-WCAWZ2042889, these two drives size close: 0 /dev/sdd 2930266584, 0 /dev/sda 2930266584
[2015/04/04 19:40:20 1192] Changed drive selction: s=4/0, t=0/0, file=/var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
[2015/04/04 19:40:20 1192] Repair md: use disk /dev/sdd, size 2930266584
[2015/04/04 19:40:23 1192] LINE 1505: exec command: sgdisk -Z /dev/sdd
other utilities.
[2015/04/04 19:40:26 1192] Update new added disk information: from /dev/sdf to /dev/sdd
[2015/04/04 19:40:26 1192] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 4718592 4718592 NO_MD 0
[2015/04/04 19:40:26 1192] partitions: 2 property: 4K
[2015/04/04 19:40:26 1192] 000 /dev/sdd1, 8, 49, 4194304 NO_MD md=
[2015/04/04 19:40:26 1192] 001 /dev/sdd2, 8, 50, 524288 NO_MD md=
[2015/04/04 19:40:26 1192] 000 /dev/sdf,WD-WCAWZ2042889,8, 80, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/04 19:40:26 1192] partitions: 3 property: 4K
[2015/04/04 19:40:26 1192] 000 /dev/sdf1, 8, 81, 4194304 MD_FULL md=/dev/md0
[2015/04/04 19:40:26 1192] 001 /dev/sdf2, 8, 82, 524288 MD_FULL md=/dev/md1
[2015/04/04 19:40:26 1192] 002 /dev/sdf3, 8, 83, 2925545912 MD_FULL md=/dev/md2
[2015/04/04 19:40:26 1192] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 2930264504 2930264504 NO_MD 0
[2015/04/04 19:40:26 1192] 002 /dev/sdd3, 0, 0, 2925545912 NO_MD md=
[2015/04/04 19:40:26 1192] Get format of pt /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
[2015/04/04 19:40:26 1192] Error unkonwn partition table /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889 !!!!
[2015/04/04 19:40:26 1192] Need to increase ext size from 0 to 0
[2015/04/04 19:40:26 1192] LINE 3717: exec command: sfdisk --force -L /dev/sdd < /var/log/frontview/.V_E.source_pt1.sav
Old situation:
No partitions found
New situation:
No partitions found
[2015/04/04 19:40:26 1192] Input target disk 4K align partition problem: 256, use old partition.
[2015/04/04 19:40:26 1192] LINE 3723: exec command: sfdisk --force -L /dev/sdd < /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
Old situation:
No partitions found
New situation:
No partitions found
[2015/04/04 19:40:26 1192] LINE 3730: exec command: sgdisk -g -a 8 /dev/sdd
[2015/04/04 19:40:29 1192] Succeed to convert mbr to gpt /dev/sda.
[2015/04/04 19:40:29 1192] Input target disk partition problem: 256
[2015/04/04 19:40:29 1192] Failed to add disk to md
[2015/04/04 19:40:29 1192] Added drive to md, grown=0/0xffd0de38
[2015/04/04 19:40:29 1192] LINE 4852: exec command: /usr/sbin/expand_md -a super >> /var/log/frontview/expand_md.log 2>&1 &
[2015/04/04 19:40:29 1192] LINE 4855: exec command: /frontview/bin/volumescan &
[2015/04/04 19:40:30 1192] STAGE_WIPE: Clean my_pid 1192
[2015/04/04 19:40:30 1688] STAGE_CHECK: saved my_pid 1688 in check mode.
[2015/04/04 19:40:30 1688] RAID MODE: 1, sn=
[2015/04/04 19:40:30 1688] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2015/04/04 19:40:30 1688] Current file system status: ext4
[2015/04/04 19:40:30 1688] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2015/04/04 19:40:31 1688] Running disk SMART quick self-test on new disk 4 [/dev/sdd]...
[2015/04/04 19:42:31 1688] PASSED
[2015/04/04 19:42:31 1688] LINE 1144: exec command: killall -HUP monitor_enclosure
[2015/04/04 19:42:32 1688] X_level: 6
[2015/04/04 19:42:32 1688] /usr/sbin/expand_md -a super
[2015/04/04 19:42:32 1688] MD degraded 1, bg_job 0, boot 0
[2015/04/04 19:42:32 1688] STAGE_WIPE: Clean my_pid 1688
Wed Apr 8 20:43:52 NZST 2015
[2015/04/08 20:43:53 31048] STAGE_CHECK: saved my_pid 31048 in check mode.
[2015/04/08 20:43:53 31048] RAID MODE: 1, sn=
[2015/04/08 20:43:53 31048] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2015/04/08 20:43:54 31048] Current file system status: ext4
[2015/04/08 20:43:54 31048] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2015/04/08 20:43:54 31048] Running disk SMART quick self-test on new disk 4 [/dev/sdd]...
[2015/04/08 20:45:54 31048] PASSED
[2015/04/08 20:45:55 31048] LINE 1144: exec command: killall -HUP monitor_enclosure
[2015/04/08 20:45:56 31048] X_level: 6
[2015/04/08 20:45:56 31048] /usr/sbin/expand_md
[2015/04/08 20:45:56 31048] MD degraded 1, bg_job 0, boot 0
[2015/04/08 20:45:56 31048] Read 1957072 byte from configuration
[2015/04/08 20:45:56 31048] configuration not same: 6 : 7
[2015/04/08 20:45:56 31048] access 2, new_disk 1, fs 4
[2015/04/08 20:45:56 31048] Disk configuration mis-matching with online configuration, can not update now...
[2015/04/08 20:45:56 31048] May need to fix array.
[2015/04/08 20:45:56 31048] new_disk_pt_count: 1
[2015/04/08 20:45:56 31048] * new disk: /dev/sdd
[2015/04/08 20:45:56 31048] ===== Partition Entry (MD not used) =====
[2015/04/08 20:45:56 31048] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 4718592 4718592 NO_MD 0
[2015/04/08 20:45:56 31048] partitions: 2 property: 4K
[2015/04/08 20:45:56 31048] 000 /dev/sdd1, 8, 49, 4194304 NO_MD md=
[2015/04/08 20:45:56 31048] 001 /dev/sdd2, 8, 50, 524288 NO_MD md=
[2015/04/08 20:45:56 31048] ===== Partition Entry (Used by MD) =====
[2015/04/08 20:45:56 31048] 000 /dev/sdb,WD-WCAWZ2042830,8, 16, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/08 20:45:56 31048] partitions: 3 property: 4K
[2015/04/08 20:45:56 31048] 000 /dev/sdb1, 8, 17, 4194304 MD_FULL md=/dev/md0
[2015/04/08 20:45:56 31048] 001 /dev/sdb2, 8, 18, 524288 MD_FULL md=/dev/md1
[2015/04/08 20:45:56 31048] 002 /dev/sdb3, 8, 19, 2925545912 MD_FULL md=/dev/md2
[2015/04/08 20:45:56 31048] 001 /dev/sdc,WD-WCAWZ2059262,8, 32, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/08 20:45:56 31048] 000 /dev/sdc1, 8, 33, 4194304 MD_FULL md=/dev/md0
[2015/04/08 20:45:56 31048] 001 /dev/sdc2, 8, 34, 524288 MD_FULL md=/dev/md1
[2015/04/08 20:45:56 31048] 002 /dev/sdc3, 8, 35, 2925545912 MD_FULL md=/dev/md2
[2015/04/08 20:45:56 31048] 002 /dev/sde,WD-WCAWZ2059507,8, 64, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/08 20:45:56 31048] 000 /dev/sde1, 8, 65, 4194304 MD_FULL md=/dev/md0
[2015/04/08 20:45:56 31048] 001 /dev/sde2, 8, 66, 524288 MD_FULL md=/dev/md1
[2015/04/08 20:45:56 31048] 002 /dev/sde3, 8, 67, 2925545912 MD_FULL md=/dev/md2
[2015/04/08 20:45:56 31048] 003 /dev/sdf,WD-WCAWZ2042889,8, 80, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/08 20:45:56 31048] 000 /dev/sdf1, 8, 81, 4194304 MD_FULL md=/dev/md0
[2015/04/08 20:45:56 31048] 001 /dev/sdf2, 8, 82, 524288 MD_FULL md=/dev/md1
[2015/04/08 20:45:56 31048] 002 /dev/sdf3, 8, 83, 2925545912 MD_FULL md=/dev/md2
[2015/04/08 20:45:56 31048] 004 /dev/sda,WD-WCAWZ1982796,8, 0, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/08 20:45:56 31048] 000 /dev/sda1, 8, 1, 4194304 MD_FULL md=/dev/md0
[2015/04/08 20:45:56 31048] 001 /dev/sda2, 8, 2, 524288 MD_FULL md=/dev/md1
[2015/04/08 20:45:56 31048] 002 /dev/sda3, 8, 3, 2925545912 MD_FULL md=/dev/md2
[2015/04/08 20:45:56 31048] in find_drive_... looking at /dev/md2
[2015/04/08 20:45:56 31048] found drive has the needed size for /dev/md2: /dev/sda, 2930266584, 2930264504
[2015/04/08 20:45:56 31048] Drive sn WD-WCAWZ1982796
[2015/04/08 20:45:56 31048] Drive sn WD-WCAWZ1982796 WD-WCAWZ1982796
[2015/04/08 20:45:56 31048] Take /dev/sda WD-WCAWZ1982796 away
[2015/04/08 20:45:56 31048] Drive sn WD-WCAWZ2042830
[2015/04/08 20:45:56 31048] Drive sn WD-WCAWZ2042830 WD-WCAWZ2042830
[2015/04/08 20:45:56 31048] Take /dev/sdb WD-WCAWZ2042830 away
[2015/04/08 20:45:56 31048] Drive sn WD-WCAWZ2059262
[2015/04/08 20:45:56 31048] Drive sn WD-WCAWZ2059262 WD-WCAWZ2059262
[2015/04/08 20:45:56 31048] Take /dev/sdc WD-WCAWZ2059262 away
[2015/04/08 20:45:56 31048] Drive sn WD-WCAWZ1978251
[2015/04/08 20:45:56 31048] Drive WD-WCAWZ1978251 missing.
[2015/04/08 20:45:56 31048] Drive sn WD-WCAWZ2059507
[2015/04/08 20:45:56 31048] Drive sn WD-WCAWZ2059507 WD-WCAWZ2059507
[2015/04/08 20:45:56 31048] Take /dev/sde WD-WCAWZ2059507 away
[2015/04/08 20:45:56 31048] Drive sn WD-WCAWZ2042889
[2015/04/08 20:45:56 31048] Drive sn WD-WCAWZ2042889 WD-WCAWZ2042889
[2015/04/08 20:45:56 31048] Take /dev/sdf WD-WCAWZ2042889 away
[2015/04/08 20:45:56 31048] Total missing: 1, index=3
[2015/04/08 20:45:56 31048] found missing drive: /dev/sdd WD-WCAWZ1978251 MD_NULL blocks=2930266584 2930264504 2930264504
[2015/04/08 20:45:56 31048] XRAID cfg_pt = WD-WCAWZ2042889, these two drives size close: 0 /dev/sdd 2930266584, 1 /dev/sdb 2930266584
[2015/04/08 20:45:56 31048] Changed drive selction: s=4/1, t=0/0, file=/var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
[2015/04/08 20:45:57 31048] Repair md: use disk /dev/sdd, size 2930266584
[2015/04/08 20:46:00 31048] LINE 1505: exec command: sgdisk -Z /dev/sdd
other utilities.
[2015/04/08 20:46:11 31048] Update new added disk information: from /dev/sdf to /dev/sdd
[2015/04/08 20:46:11 31048] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 4718592 4718592 NO_MD 0
[2015/04/08 20:46:11 31048] partitions: 2 property: 4K
[2015/04/08 20:46:11 31048] 000 /dev/sdd1, 8, 49, 4194304 NO_MD md=
[2015/04/08 20:46:11 31048] 001 /dev/sdd2, 8, 50, 524288 NO_MD md=
[2015/04/08 20:46:11 31048] 000 /dev/sdf,WD-WCAWZ2042889,8, 80, 2930266584 2930264504 2930264504 MD_FULL 0
[2015/04/08 20:46:11 31048] partitions: 3 property: 4K
[2015/04/08 20:46:11 31048] 000 /dev/sdf1, 8, 81, 4194304 MD_FULL md=/dev/md0
[2015/04/08 20:46:11 31048] 001 /dev/sdf2, 8, 82, 524288 MD_FULL md=/dev/md1
[2015/04/08 20:46:11 31048] 002 /dev/sdf3, 8, 83, 2925545912 MD_FULL md=/dev/md2
[2015/04/08 20:46:11 31048] 000 /dev/sdd,WD-WCC4E1ESZ1LX,8, 48, 2930266584 2930264504 2930264504 NO_MD 0
[2015/04/08 20:46:11 31048] 002 /dev/sdd3, 0, 0, 2925545912 NO_MD md=
[2015/04/08 20:46:11 31048] Get format of pt /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
[2015/04/08 20:46:11 31048] Error unkonwn partition table /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889 !!!!
[2015/04/08 20:46:11 31048] Need to increase ext size from 0 to 0
[2015/04/08 20:46:11 31048] LINE 3717: exec command: sfdisk --force -L /dev/sdd < /var/log/frontview/.V_E.source_pt1.sav
Old situation:
No partitions found
New situation:
No partitions found
[2015/04/08 20:46:15 31048] Input target disk 4K align partition problem: 256, use old partition.
[2015/04/08 20:46:15 31048] LINE 3723: exec command: sfdisk --force -L /dev/sdd < /var/log/frontview/.known_cfgdir/WD-WCAWZ2042889
Old situation:
No partitions found
New situation:
No partitions found
[2015/04/08 20:46:20 31048] LINE 3730: exec command: sgdisk -g -a 8 /dev/sdd
[2015/04/08 20:46:30 31048] Succeed to convert mbr to gpt /dev/sdb.
[2015/04/08 20:46:30 31048] Input target disk partition problem: 256
[2015/04/08 20:46:30 31048] Failed to add disk to md
[2015/04/08 20:46:30 31048] Added drive to md, grown=0/0xffc6e768
[2015/04/08 20:46:30 31048] LINE 4852: exec command: /usr/sbin/expand_md -a super >> /var/log/frontview/expand_md.log 2>&1 &
[2015/04/08 20:46:36 31048] LINE 4855: exec command: /frontview/bin/volumescan &
[2015/04/08 20:46:46 31048] STAGE_WIPE: Clean my_pid 31048
[2015/04/08 20:47:32 31651] STAGE_CHECK: saved my_pid 31651 in check mode.
[2015/04/08 20:47:32 31651] RAID MODE: 1, sn=
[2015/04/08 20:47:32 31651] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2015/04/08 20:47:33 31651] Current file system status: ext4
[2015/04/08 20:47:33 31651] LINE 5305: exec command: rm -fr /var/log/frontview/.V_E.*
[2015/04/08 20:47:33 31651] Running disk SMART quick self-test on new disk 4 [/dev/sdd]...
[2015/04/08 20:49:34 31651] PASSED
[2015/04/08 20:49:34 31651] LINE 1144: exec command: killall -HUP monitor_enclosure
[2015/04/08 20:49:35 31651] X_level: 6
[2015/04/08 20:49:35 31651] /usr/sbin/expand_md -a super
[2015/04/08 20:49:35 31651] MD degraded 1, bg_job 0, boot 0
[2015/04/08 20:49:35 31651] STAGE_WIPE: Clean my_pid 31651
