Quinny1
Apr 09, 2015Aspirant
Ultra 6 - Dead drive, Replaced but won't Rebuild #24999085
I have a ReadyNAS Ultra 6 in Raid 6 which was 98% full. RAIDiator 4.2.25 Wed Jan 7 12:56:48 NZDT 2015 Disk failure detected. Wed Jan 7 12:57:01 NZDT 2015 ..... If this disk is a part of a RAI...
Quinny1
Apr 17, 2015Aspirant
Just for anyone else that gets stuck a very skilled sys admin friend (tired of my moaning I think :D) remoted into the box from where he lives in another city (I opened port in router my end and gave admin access - I have known him ages so I was ok with this. He had actually remoted to my pc a few weeks ago to try from there with no luck).
Anyway some twiddling later he has it fixed.
time goes by then
Special thanks to MDGM for keeping on trying to help via PM. I did buy the second disk and had the same fail after trying with that and was waiting to hear back from MDGM when his timezone caught up with mine when out of the blue my friend offered to help. It was looking rather bleek so I am really happy it is now fixing. I will post up his notes for others when I get them.
- cg OOoo
cg Disk /dev/sdd: 364801 cylinders, 255 heads, 63 sectors/track
cg Units = cylinders of 8225280 bytes, blocks of 1024 bytes, counting from 0
cg Device Boot Start End #cyls #blocks Id System
cg /dev/sdd1 0+ - 0- 2147483647+ ee EFI GPT
cg /dev/sdd2 0 - 0 0 0 Empty
cg /dev/sdd3 0 - 0 0 0 Empty
cg /dev/sdd4 0 - 0 0 0 Empty
cg we finally have a partition table on your new disk
cg QuinnyNAS:~# sgdisk -R /dev/sdd /dev/sdf
cg sdf is one of your existing drives, i just cloned that over
time goes by then
- cg guess what
cg QuinnyNAS:~# cat /proc/mdstat
cg Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
cg md2 : active raid6 sdd3[6] sda3[0] sdf3[5] sde3[4] sdc3[2] sdb3[1]
cg 11702178816 blocks super 1.2 level 6, 64k chunk, algorithm 2 [6/5] [UUU_UU]
cg [>....................] recovery = 0.0% (174720/2925544704) finish=8649.8min speed=5636K/sec
cg resyncing
cg i'll email you an extract of what I did so you can update the thread. it might help someone in future
