AdamHonse
Oct 20, 2013Follower
Ultra 6 and 6 3TB HD in raid 5 creates 15TB volume
Hello, I purchased the Ultra 6 a while ago and am finally getting around to populate it with Hard drives. I would like to maximize space and redundancy, and i think what i list below will work, Can...
mdgm-ntgr
Oct 20, 2013NETGEAR Employee Retired
I would recommend RAID-6 (or X-RAID2 dual-redundancy) not RAID-5 (or X-RAID2 single-redundancy) with high capacity disks, but yes you could do that.
Note the Ultra 6 needs to be running 4.2.16 or later to support 3TB drives. Put one disk in, update the firmware, verify the update was successful, then power down, put the rest of the disks in and do a factory default.
