l23
Jan 14, 2022Aspirant
Ultra 6 Plus - freezing after upgrade from 4.2.31 to 6.x
Hello, I have an old unit Ultra 6 Plus, which was running RAIDiator 4.2.31 I upgraded to ver 6.9.3 as per these instructions https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/U...
Jan 15, 2022Guru - Experienced User
In recent years we've recommending upgrading the RAM to 2 GB when doing the conversion. If you haven't done that, then I suggest doing that next.
l23
Jan 16, 2022Aspirant
Unfortunatelly, even after the memory upgrade to 4 Gb, it still freezes. Perhaps it's just a perception, but it seemed to be stable for longer (few good hours) before it froze.
StephenB Any other suggestions?
Bios is old (06/10/2010 FLAME6-2 V1.1) - I now see it's quite a process to upgrade it, I should've done it before upgrading to OS6.
Thanks in advance for other suggestions
- Jan 17, 2024Retired_Member
