l23
Jan 14, 2022Aspirant
Ultra 6 Plus - freezing after upgrade from 4.2.31 to 6.x
Hello, I have an old unit Ultra 6 Plus, which was running RAIDiator 4.2.31 I upgraded to ver 6.9.3 as per these instructions https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/U...
Jan 16, 2022Guru - Experienced User
l23 wrote:
I tried to downgrade the firmware to 6.9.3 (the one I initally upgraded to), but it tells me file is not valid.
You'd need to use the reall 6.9.3 firmware, not the slightly hacked one used in the conversion. Though Netgear generally doesn't support downgrades to previous major revisions (e.g., 6.10.x to 6.9.x).
FWIW, current firmware is 6.10.6, so you could try that before downgrading.
l23 wrote:@StephenB Any other suggestions?
Have you gone through the log zip file?
- l23Jan 16, 2022Aspirant
StephenB Thank you
I am on 6.10.6
I understand regarding the downgrade, I see 6.9.3 here https://kb.netgear.com/000055199/ReadyNAS-OS-6-Software-Version-6-9-3
Should I downgrade directly to that version? Or I should try going backwards to 6.10.6, 6.10.5, 6.10.4 etc
I did check the logs (I am still finding my way around there) - in the system.log I have the following before I rebooted the unit:
Jan 16 05:39:48 ReadyNASUltra6 dbus[2893]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper)
Jan 16 05:39:48 ReadyNASUltra6 dbus[2893]: [system] Successfully activated service 'org.opensuse.Snapper'
Jan 16 05:41:07 ReadyNASUltra6 msmtpq[18154]: mail [ 1 ] [ 2022-01-15-18.27.46 ] from queue ; send failed ; msmtp rc = 76
Jan 16 05:41:09 ReadyNASUltra6 msmtpq[18197]: 2 more mails from queue failed to send with rc = 76
Jan 16 05:47:27 ReadyNASUltra6 connmand[2899]: ntp: adjust (slew): -0.000245 sec
Jan 16 05:51:10 ReadyNASUltra6 msmtpq[18324]: mail [ 1 ] [ 2022-01-15-18.27.46 ] from queue ; send failed ; msmtp rc = 76
Jan 16 05:51:11 ReadyNASUltra6 msmtpq[18367]: 2 more mails from queue failed to send with rc = 76
Jan 16 05:58:45 ReadyNASUltra6 mdadm[2890]: RebuildFinished event detected on md device /dev/md127, component device resync: mismatches found: 1518992896 (on raid level 5)
Jan 16 05:58:56 ReadyNASUltra6 msmtpq[18470]: mail for [ -C /etc/msmtprc @[email protected],[email protected] --timeout=60 ] : send was unsuccessful ; msmtp exit code was 76
Jan 16 05:58:56 ReadyNASUltra6 msmtpq[18472]: enqueued mail as : [ 2022-01-16-05.58.55 ] ( -C /etc/msmtprc @[email protected],[email protected] --timeout=60 )
Jan 16 06:01:22 ReadyNASUltra6 msmtpq[18524]: mail [ 1 ] [ 2022-01-15-18.27.46 ] from queue ; send failed ; msmtp rc = 76
Jan 16 06:01:24 ReadyNASUltra6 msmtpq[18587]: 3 more mails from queue failed to send with rc = 76
Jan 16 06:04:31 ReadyNASUltra6 connmand[2899]: ntp: adjust (slew): +0.000613 sec
Jan 16 06:11:25 ReadyNASUltra6 msmtpq[18700]: mail [ 1 ] [ 2022-01-15-18.27.46 ] from queue ; send failed ; msmtp rc = 76
Jan 16 06:11:26 ReadyNASUltra6 msmtpq[18763]: 3 more mails from queue failed to send with rc = 76
Jan 16 06:17:01 ReadyNASUltra6 CRON[18814]: pam_unix(cron:session): session opened for user root by (uid=0)
Jan 16 06:17:01 ReadyNASUltra6 CRON[18815]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Jan 16 06:17:01 ReadyNASUltra6 CRON[18814]: pam_unix(cron:session): session closed for user root-- Reboot --
Jan 16 13:03:52 ReadyNASUltra6 cron[2886]: (CRON) INFO (pidfile fd = 3)
Jan 16 13:03:52 ReadyNASUltra6 cron[2886]: (CRON) INFO (Running @reboot jobs)
Jan 16 13:03:52 ReadyNASUltra6 wsdd2[2887]: starting....
If I am reading this correctly, it froze at 6:17 AM - and I powered it off/restarted at 13:03
I did have another problem which I didn't mention before, because it shouldn't be tied to this freezing issue. I tried setting alerts with both gmail and yahoo addresses, it didn't work, it looks like both companies tightened up security (solutions I found in other threads didn't work for me). But I just configured it using another email account and was able to send a test.
- StephenBJan 18, 2022Guru - Experienced User
It'd be good to see what was in the emails that failed to send.
Yes, that is what it looks like.
- SandsharkJan 17, 2022Sensei
The Ultra6 BIOS in the BIOS upgrade package is RN_Ultra6_061010.ROM, so I believe you have the latest.
- Jan 17, 2024Retired_Member
