l23
Jan 14, 2022Aspirant
Ultra 6 Plus - freezing after upgrade from 4.2.31 to 6.x
Hello, I have an old unit Ultra 6 Plus, which was running RAIDiator 4.2.31 I upgraded to ver 6.9.3 as per these instructions https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/U...
Jan 16, 2022Guru - Experienced User
l23 wrote:
I tried to downgrade the firmware to 6.9.3 (the one I initally upgraded to), but it tells me file is not valid.
You'd need to use the reall 6.9.3 firmware, not the slightly hacked one used in the conversion. Though Netgear generally doesn't support downgrades to previous major revisions (e.g., 6.10.x to 6.9.x).
FWIW, current firmware is 6.10.6, so you could try that before downgrading.
l23 wrote:@StephenB Any other suggestions?
Have you gone through the log zip file?
Sandshark
Jan 17, 2022Sensei
The Ultra6 BIOS in the BIOS upgrade package is RN_Ultra6_061010.ROM, so I believe you have the latest.
- Jan 17, 2024Retired_Member
