CharlesR
Sep 20, 2014Guide
Ultra Plus Upgrade from Beta 6.1.9 to Release 6.1.9
I just downloaded and rebooted the release firmware from the latest beta and the unit appears to be working away but it's not found on the network. My Wake On Lan utility reports it being offline. Sho...
CharlesR
Sep 20, 2014Guide
Just came up fine... looking around. From the log it appears it rebooted fine during the upgrade...
Fri Sep 19 2014 20:10:38
System: ReadyNASOS background service started.
Fri Sep 19 2014 20:08:25
System: The system is rebooting.
Here's where you rebooted it...
Fri Sep 19 2014 21:47:47
Fri Sep 19 2014 21:47:46
System: ReadyNASOS service or process was restarted.
I presume using a fixed IP wouldn't matter... what type of network issue(s) did you see? If it would help in anyway I could retry the upgrade again... if it's perhaps a generic issue not unique to me.
And I much appreciate you taking a look!
