CharlesR
Sep 20, 2014Guide
Ultra Plus Upgrade from Beta 6.1.9 to Release 6.1.9
I just downloaded and rebooted the release firmware from the latest beta and the unit appears to be working away but it's not found on the network. My Wake On Lan utility reports it being offline. Sho...
CharlesR
Sep 20, 2014Guide
mdgm wrote: It couldn't find the apt archive which sounds like a DNS or Gateway issue.
If it helps it has a fixed IP address off of a switch then a DD-WRT router (doing DHCP) which is connected to a Internet gateway/router.
I think I can handle your PM. Thanks again.
