Amien
Dec 22, 2013Aspirant
Ultra6 expansion failed
Sun Dec 22 16:20:57 CET 2013 Volume expansion failed
Sat Dec 21 12:52:11 CET 2013 Volume expansion or migration started. Do not interrupt the system during this time. When finished, email notification will be sent to the alert contact list.
I had 5x3TB disks inserted (1 redundant). Total space was 10.9TB. After a few months i added a 6th one .. And after 24hours or so, i get the above message.
The 6th is green in FrontView. But the totale space is still 10.9TB
How can i fix this? turn nas off, remove 6th, boot up again and then insert again?
i did offline expansion when i added the 5th disk .. do i need to do this again??
Thanks in advanced
- AmienAspirantStill looking for a solution beside factory reset. i thought on the last offline expansion i didn't use a USBStick to create a swap file. but just a swap file on the NAS. This shouldn't matter right?
- AmienAspirantSolved!! i created an additional swap file (on on NAS and one on USBstick) and it did work .. i now have 13TB of space
- AmienAspirant@StephenB .. could you please unban my account? i know it was a bit a spam? I was banned for that reason? Can you unban me, i would like to use this forum again in the future
- mdgm-ntgrNETGEAR Employee RetiredI don't think your account is banned. If it was you couldn't make new posts.
- AmienAspirantI need a proxy to reach this forum. Otherwise i will get
This
Forbidden
You don't have permission to access /forum/viewtopic.php on this server. - mdgm-ntgrNETGEAR Employee RetiredAh that means your I.P. has been banned. Can you PM me your I.P. and I will look into this.
