Laureijs
Feb 17, 2020Aspirant
Ultra6 stuck on Boot Menu
Just checked the central heating an noticed: Boot Menu on my Ultra6 on OS6 I probably need to emergency boot usb, but since I upgraded to OS6 I suppose I need to use the modded BIOS? (system ...
Feb 17, 2020Guru - Experienced User
Laureijs wrote:
(system is unresponsive and just sits there, pressing reset doesn't make any difference)
If you hold down the power button, the system should turn off after several seconds. Then power on again, and tell us if it boots normally (and if not what error message you see).
RAIDar might also give you some useful status: https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
- LaureijsFeb 17, 2020Aspirant
The system shuts of immediately when pressing power.
Upon reboot: Readynas logo and a short attempt to boot: I see 1-4 stripes from the progress bas and the Boot Menu
This nas is not found by raidar
- StephenBFeb 17, 2020Guru - Experienced User
This is with no disks installed?
with drives, but then again: there's no network connection (no light on device as well as the connected switch)
tried another psu: no dice
