Laureijs
Feb 17, 2020Aspirant
Ultra6 stuck on Boot Menu
Just checked the central heating an noticed: Boot Menu on my Ultra6 on OS6 I probably need to emergency boot usb, but since I upgraded to OS6 I suppose I need to use the modded BIOS? (system ...
Laureijs
The system shuts of immediately when pressing power.
Upon reboot: Readynas logo and a short attempt to boot: I see 1-4 stripes from the progress bas and the Boot Menu
This nas is not found by raidar
Feb 17, 2020Guru - Experienced User
This is with no disks installed?
- LaureijsFeb 17, 2020Aspirant
with drives, but then again: there's no network connection (no light on device as well as the connected switch)
tried another psu: no dice
Also without drives
StephenB wrote:
Laureijs wrote:The system shuts of immediately when pressing power.
- StephenBFeb 17, 2020Guru - Experienced User
Laureijs wrote:
Also without drivesOk. I guess a USB recovery would be the next thing to try.
You'd use the instructions for 4.2.x, but you'd use the OS-6 firmare image. That needs to be renamed to RAIDiator-x86-4.2.31 (with no file extension)
- LaureijsFeb 18, 2020Aspirant
Ok, created an usb recovery, copied and renamed the latest OS fw.
Power on, hold backup for 10-15 sec, the led on the usb stick flashes and after a minute of so the unit shuts off (as expected)
But on reboot: same behaviour: the unit goes straight to the (unresponsive) boot menu
