smoggypaul
May 28, 2012Aspirant
Unable to connect to IP address
I just changed my broadband supplier and have had to change the router to a Sky [Sagem] box [from a Belkin] - my Duo had been running happily for about 6 months but has now disappeared. I can see it i...
May 29, 2012Guru - Experienced User
I'm glad you are up and running.
If you want a stable IP address for the NAS, you should look through the router menus and see if it supports DHCP reservations. That lets you assign the IP at the router, so if you change ISPs again the problem won't recur.
