leamlane
Jul 10, 2024Aspirant
unable to login to admin acount on nas duo RND2000 v2
Cannot log in to admin account after upgrade to Firefox and edge Internet Explorer. Get the following error message:- Secure Connection Failed An error occurred during a connection to 192.168.68...
Jul 10, 2024Guru - Experienced User
Sandshark wrote:
or turn on TLS1.1 support in one that still does. I believe FireFox is one where you can still do that.
Yes. Set security.tls.version.min to 1 (browse to about:config and search for the setting).
Sandshark wrote:
Your ancient NAS does not support TLS V1.2.
Once you regain access, there are a couple of other potential options.
- it is possible to make a simple mod to virtual.conf that would let you log into the web ui using http (unencrypted)
- If you truly have a v2, there is also an add-on that will give you TLS 1.2 support
Note that many owners of the original Duo mistakenly believe they have a v2.
The Duo v2
- says "ReadyNAS Duo v2" on the front panel
- runs 5.3.x firmware.
The confusion happens because there are often other labels on the original Duo that include a v2. These need to be ignored when identifying the model.
After you can confirm the model we can give you some more details on these options.
leamlane
Found a temp soloution here:-
https://www.trishtech.com/2020/03/how-to-enable-tls-1-0-and-tls-1-1-in-mozilla-firefox-74/
- saudadeJul 10, 2024Apprentice
What StephenB said. My Duo says V2 for the model number on the sticker but no V2 on the front door. It's a V1.
Mine runs 4.1.16 (the last update).
- Apr 16, 2020Retired_Member
