ankitrana
Feb 05, 2020Tutor
Unable to mount Mediasonc Proraid HUR5SU3 USB drive(s)
Hi, I have a mediasonic proraid device with two HDD (4TB each) configured as single to show up as separate USB devices. I have used this before and it used to work perfectly, and now for some re...
- Feb 05, 2020
ankitrana wrote:
So there you have it....well why does it say so ??
The NAS does support NTFS (your other drives are formatted that way). But it does use a third-party package to do that.
I'm guessing it might be the Paragon software. If I'm right, then
# mount -t ufsd /dev/sdg2 /media/USB_HDD_3
might work.
Feb 05, 2020Guru - Experienced User
As you can see from the df command, normally it would be mounted as /media/USB_HDD_x
So you can look in /media, and find a USB_HDD folder that isn't being used (for example USB_HDD_2), and try mounting with
# mount /dev/sdf2 /media/USB_HDD_2
Then see if the expected files and folders show up in /media/USB_HDD_2.
However, this might not be enough to access the drive with file explorer or the web ui.
- ankitranaFeb 05, 2020Tutor
Hi there, first of all thanks for your response, really appreciate it.
So i had all the USB drive plugged out, so after pluging in "the USB", this time around the other drive came up.
Output of blkid:
/dev/md124: LABEL="601d24b6:HD4" UUID="e4dcb617-f0d1-4893-98d3-e1133fcf72fa" UUID_SUB="4d52c64a-0014-49b5-a871-140d19cbe9a2" TYPE="btrfs" /dev/ubi0_0: UUID="523402c5-1fde-4e21-8c12-d6280c228fcc" TYPE="ubifs" /dev/sdf1: LABEL="EFI" UUID="67E3-17ED" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="a1dc84ab-bafb-4995-9ca5-20c677bbc796" /dev/sdf2: LABEL="T4" UUID="188CADA78CAD7FBC" TYPE="ntfs" PARTUUID="6fc1405c-8b98-4ebc-9ce2-52279285306f" /dev/sdg1: LABEL="EFI" UUID="67E3-17ED" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="b21fb00d-b96d-4c56-9221-4d9be8363692" /dev/sdg2: LABEL="T3" UUID="4430AF6030AF57A6" TYPE="ntfs" PARTUUID="1e3c1068-b528-4f5f-8892-2e4fe97a2e3e"
and of df -h
Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 3.7G 916M 2.6G 26% / tmpfs 1009M 0 1009M 0% /dev/shm tmpfs 1009M 3.4M 1006M 1% /run tmpfs 505M 1.1M 504M 1% /run/lock tmpfs 1009M 0 1009M 0% /sys/fs/cgroup /dev/md125 3.7T 924G 2.8T 25% /HD3 /dev/md126 3.7T 1.3T 2.4T 35% /HD2 /dev/md126 3.7T 1.3T 2.4T 35% /home /dev/md126 3.7T 1.3T 2.4T 35% /apps /dev/md127 3.7T 516G 3.2T 14% /HD1 /dev/md124 3.7T 210G 3.5T 6% /HD4 /dev/md126 3.7T 1.3T 2.4T 35% /var/ftp/SDL /dev/md125 3.7T 924G 2.8T 25% /var/ftp/test /dev/md124 3.7T 210G 3.5T 6% /run/nfs4/HD4/Ankit /dev/md127 3.7T 516G 3.2T 14% /run/nfs4/HD1/download tmpfs 4.0K 0 4.0K 0% /home/admin/snapshot tmpfs 4.0K 0 4.0K 0% /home/uNAS/snapshot /dev/sdf2 3.7T 577G 3.1T 16% /media/USB_HDD_4
so i modified your command and ran
root@BhaiyaJi:/home/admin# mount /dev/sdg2 /media/USB_HDD_3 mount: mount point /media/USB_HDD_3 does not exist root@BhaiyaJi:/home/admin# ls /media/ USB_HDD_4
so i created a new folder and tried to mount
root@BhaiyaJi:/home/admin# mkdir /media/USB_HDD_3 root@BhaiyaJi:/home/admin# ls /media/ USB_HDD_3 USB_HDD_4 root@BhaiyaJi:/home/admin# mount /dev/sdg2 /media/USB_HDD_3 mount: unknown filesystem type 'ntfs'
- StephenBFeb 05, 2020Guru - Experienced User
might work.
Yes that did work, i can access all the folders and it seems it has all the data.
And as you said they did not appear in the GUI or shared folders list...
Can you help me to fix this issue, it should have mounted and available accross share automatically
