bnor82
Nov 25, 2014Aspirant
Unable to retrieve data from ReadyNAS Duo
Hi All, I had a ReadyNAS duo which has, for want of better words, "blown up" on me! I am trying to recover the data off the drive with little success despite vast amounts of reading on this forum,...
bnor82
Hi mdgm, thanks for your reply!
I had two disk in the NAS and i believe i was using raid0, which i believe is X-RAID?
I have checked the other disk but there appears to be naff all on that one.
It appears that that partition is 2GB :?
$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/sda1 33G 4.6G 27G 15% /
none 4.0K 0 4.0K 0% /sys/fs/cgroup
udev 984M 4.0K 984M 1% /dev
tmpfs 200M 1.3M 199M 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 998M 76K 998M 1% /run/shm
none 100M 32K 100M 1% /run/user
/dev/sdc1 466G 60G 407G 13% /media/bevan/430A-5764
/dev/sdb1 2.0G 364M 1.6G 19% /mnt/foo
df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/sda1 2162688 186634 1976054 9% /
none 255391 2 255389 1% /sys/fs/cgroup
udev 251685 513 251172 1% /dev
tmpfs 255391 543 254848 1% /run
none 255391 2 255389 1% /run/lock
none 255391 4 255387 1% /run/shm
none 255391 15 255376 1% /run/user
/dev/sdc1 0 0 0 - /media/bevan/430A-5764
/dev/sdb1 128000 10210 117790 8% /mnt/foo
