bnor82
Nov 25, 2014Aspirant
Unable to retrieve data from ReadyNAS Duo
Hi All,
I had a ReadyNAS duo which has, for want of better words, "blown up" on me!
I am trying to recover the data off the drive with little success despite vast amounts of reading on this forum, which has been very helpful.
Despite my efforts i seem unable to recover the data all though it appears I can access the system partition without issue.
Below is the output of fdisk -l on the drive in question:
I can mount /dev/sdb1 ok using: ~ $ sudo fuseext2 -o ro,allow_other /dev/sdb1 /mnt/foo/
Once this is mounted i can see the filesystem of the ReadyNAS but cant actually access any of my data:
applications, backup, media and private all come up as sym links to /c/<respective folder> but there is no data in the c folder.
Additionally, based on other posts, i have tried to do a vgscan, pvscan to try and change into volume group c however:
Would really appreciate if anyone could assist as I have years of photos on this device, please spare the have you got a backup!
Am i doing something wrong when I mount the filesystem? Should i be looking in one of the other partitions for my actual files?
Any help, anyone can offer will be greatly appreciated!
Thanks in advance :)
~ $ sudo fdisk -l /dev/sdb
Disk /dev/sdb: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0xd80ce136
Device Boot Start End Blocks Id System
/dev/sdb1 2 4096001 2048000 83 Linux
/dev/sdb2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/sdb3 4608002 1953092233 974242116 5 Extended
/dev/sdb5 4608003 1953092233 974242115+ 8e Linux LVM
$ ls /mnt/foo
applications c frontview lib mnt proc sbin USB
backup dev home lost+found opt ramfs sys usr
bin etc initrd media private root tmp var
sudo vgscan
Reading all physical volumes. This may take a while...
No volume groups found
sudo pvscan
No matching physical volumes found
- mdgm-ntgrNETGEAR Employee RetiredWhat Linux OS are you using?
What version of fuseext2? - bnor82AspirantI am using Linux mint and fuseext2 0.4-1.1
- StephenBGuru - Experienced UserHow exactly did the NAS fail?
If you have a windows PC available you could also try the eval raid recovery software here and see if it can find your data: http://www.diskinternals.com/raid-recovery/ - bnor82AspirantHi StephenB, thanks for your response!
The NAS failed on power supply, I have opened it up and there are black marks around chips on the power supply board so think it is terminal.
Whilst i am not bad with a soldering iron these components are beyond my equipment and skills unfortunatley!
Downloaded diskinternals but could not find my data :(
Being that we have confimred i was using RAID-X i dont understand why nothing is on the other drive whatsoever.
Currently running a testdisk scan on that one to see if i can find any partitions....dont think this is looking good for my data :(
Any further suggestions greatly appreciated! - mdgm-ntgrNETGEAR Employee RetiredThe second disk is not blank. With X-RAID on Sparc, the second disk is the dedicated parity disk. It does not have the partition table on it, so your PC thinks it is blank when it really isn't.
Newer models use distributed parity. - StephenBGuru - Experienced Usermdgm might have some ideas on how to fix your mount options, it doesn't to like the 16384 block size.
The freeware Linux Reader package (http://www.diskinternals.com/linux-reader/) can access the first [data] disk if you can connect the disk to a Windows system.mdgm wrote: The second disk is not blank. With X-RAID on Sparc, the second disk is the dedicated parity disk. It does not have the partition table on it, so your PC thinks it is blank when it really isn't.
But it can't read the data from the parity disk, which is a problem if the Duo failure corrupted the data disk somehow. The raid recovery software in my earlier link might work with the parity disk - if the eval sees the data, you'd need to purchase the software I think.
Netgear also offers recovery services - you pay up front, with no guarantee of success.
Your last option is to get a used duo v1 or nv+ from somewhere, and install the disks in it. We have seen some reports here of people selling broken NAS, so there is some risk there too.
