saintalfonzo
May 12, 2021Guide
Unable to set share quota on ReadyNAS 214 running 6.10.4 hot fix 1
Hello, I am unable to set the quota for a share that I created. When I check the box to enable a quota and specify an amount, whenever I click OK or Apply, the dialog simply changes the Size labe...
- May 13, 2021
If quotas are not already enabled for the volume, setting a quota for a share is supposed to prompt you and let you know that setting a share quota will enable quotas for the volume. Perhaps somethine is amiss there. Try disabling and re-enabling volume quotas, or just manually enable them if they aren't already.
May 13, 2021Guru - Experienced User
Note you are trying to set quota for a share, and not a volume.
I'm not having any trouble with setting a 640 GB quota on a test share on my own NAS running 6.10.5 firmware. What firmware are you running?
Can you try creating an empty test share, and see if you can set the quota on it?
Sandshark
May 13, 2021Sensei
- StephenBMay 13, 2021Guru - Experienced User
I checked that on my RN102 (6.10.5), and I did get the prompt.
- saintalfonzoMay 13, 2021Guide
Don't know what was amiss, but disabling volume quotas and re-enabling first volume then the share quota seems to have fixed it.
Thank you for the suggestion, Sandshark !
- SandsharkMay 13, 2021Sensei
That's great. It was partially a guess. But others have reported funny issues with quotas that are fixed that way, so I figured it was worth a shot.
