saintalfonzo
May 12, 2021Guide
Unable to set share quota on ReadyNAS 214 running 6.10.4 hot fix 1
Hello, I am unable to set the quota for a share that I created. When I check the box to enable a quota and specify an amount, whenever I click OK or Apply, the dialog simply changes the Size labe...
- May 13, 2021
If quotas are not already enabled for the volume, setting a quota for a share is supposed to prompt you and let you know that setting a share quota will enable quotas for the volume. Perhaps somethine is amiss there. Try disabling and re-enabling volume quotas, or just manually enable them if they aren't already.
Sandshark
May 13, 2021Sensei
May 13, 2021Guru - Experienced User
I checked that on my RN102 (6.10.5), and I did get the prompt.
