bmouton
Oct 17, 2012Aspirant
Unable to switch from 100Mb to Gigabit on Readynas Duo
Hi all, I'm unable to make my ReadyNas Duo (V1) switch from 100Mb Full Duplex to Gigabit speed. My Router is a Netgear WNDR4500 and my NAS is connected directly to my router. On the back of my NA...
HERBIEO
It should automatically negotiate the speed maybe thats why it does not show Gigabit speed but i am not sure as i dont have a Duo v1,
but i have the same router as you so if you check the led's on the front panel of the router it shows what speed devices are connected at.
LAN ports 1–4
• Solid green. The LAN port has detected a 1,000 Mpbs link with an attached device.
• Solid amber. The LAN port has detected a 10/100 Mbps link with an attached device.
• Off. No link is detected on this port.
LAN ports 1–4
