BotanyBay
Aug 25, 2017Tutor
Understanding Migration using ReadyDR to new device and preserve ALL of the current snapshots
Looking to have two NAS units which are syncronized INCLUDING snapshots: I have been happily running my pro6 for many years, backed up a year ago and migrated to 6.6.0 and have continuously upgra...
BotanyBay
Aug 26, 2017Tutor
Interesting...
In another comment there is an "export a seed" for the readyDR archive. I wonder what that would pull across.
Sounds like I may have to get my hands on a second readyNAS device and try some of these things and report back... Perhaps a small two bay readynas is in my future... I think it has to be x86 based or some of the features may not be available....
Aug 26, 2017Guru - Experienced User
Correct. Look for the RN422. The RN312 might still be on the shelves, but the RN422 is replacing it. (The RN312 is still supported of course, so if you see a good deal on it, perhaps consider it too).
- BotanyBayAug 26, 2017Tutor
Thanks for the heads up on the 422 vs 312 units. I will report back when I have some results.
- BotanyBaySep 15, 2017Tutor
Well, bit the bullet and bought the 626x and a couple of 10TB IronWolf drives, planning on testing this question as I go through the process of ending up with a backup machine and a primary machine (while retaining offite backups too).
Planning on testing several of the options prior to making this new box a production server and should answer the questions I posed along the way in this link.
I went ahead and updated the new box to 6.8.0 after reading the release notes but did not notice the comment about not being able to use the UI to install apps. It notes there is a manual approach. I have uploaded apps directly in the past (primary machine never sees the internet) but still used the UI if I remember correctly. There is a comment that it will be fixed in 6.8.1, any comment on when that build will become available. This is currently not a production server so I could run a beta build and will look around at those.
Thanks
- StephenBSep 15, 2017Guru - Experienced User
Netgear generally won't say, but I think it will be quite soon. It's at release candidate 2 now, and 6.9.0 beta just started in parallel.
