FireWalkerX
May 22, 2013Aspirant
Unstable Ultra 6 (Case Number: 21215060)
So i bought a new Readynas Ultra 6, about 22 days ago, it will freeze once in a while 3 times a week. change the networking cable ive done a memory test (ran it for 12 hours) no errors ive update...
May 24, 2013Guru - Experienced User
Problems with jumbo frames can create a lot of odd issues, so your guess is quite possible.
You are entitled to 90-day phone support after purchase [assuming you are not buying used] so you could try using that if you still see these lockups.
