FireWalkerX
May 22, 2013Aspirant
Unstable Ultra 6 (Case Number: 21215060)
So i bought a new Readynas Ultra 6, about 22 days ago, it will freeze once in a while 3 times a week.
change the networking cable
ive done a memory test (ran it for 12 hours) no errors
ive updated to latest version (.23), and right now done a factory reset, and waiting for it to resync, then i looked at the logs and found the following in dmesg:
the part im wondering about is:
but it shows up with 8.1 TB of storage, so, is the disc bad, or is it not?
EDIT: well i swapped disc 4 with disc 3, but still get the same, so the disc is aparrently not bad, the question is then, is it normal behaviour, or is there a problem with
the hardward/enclosure. ill do the tests i did before to provoke the freezing - copying over 3.14 T of data...
attached below is smart status for disc 4 (no errors?)
sda: unknown partition table
sda: sda1 sda2 sda3
sdb: unknown partition table
sdb: sdb1 sdb2 sdb3
sdc: unknown partition table
sdc: sdc1 sdc2 sdc3
sdd: unknown partition table
sdd: sdd1 sdd2 sdd3
md: bind<sda1>
md: bind<sdb1>
md: bind<sdc1>
md: bind<sdd1>
bio: create slab <bio-1> at 1
md/raid1:md0: not clean -- starting background reconstruction
md/raid1:md0: active with 4 out of 4 mirrors
md0: detected capacity change from 0 to 4293906432
md: resync of RAID array md0
md: minimum _guaranteed_ speed: 1000 KB/sec/disk.
md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for resync.
md: using 128k window, over a total of 4193268 blocks.
md: bind<sda2>
md: bind<sdb2>
md: bind<sdc2>
md: bind<sdd2>
md/raid:md1: not clean -- starting background reconstruction
md/raid:md1: device sdd2 operational as raid disk 3
md/raid:md1: device sdc2 operational as raid disk 2
md/raid:md1: device sdb2 operational as raid disk 1
md/raid:md1: device sda2 operational as raid disk 0
md/raid:md1: allocated 4272kB
md/raid:md1: raid level 6 active with 4 out of 4 devices, algorithm 2
RAID conf printout:
--- level:6 rd:4 wd:4
disk 0, o:1, dev:sda2
disk 1, o:1, dev:sdb2
disk 2, o:1, dev:sdc2
disk 3, o:1, dev:sdd2
md1: detected capacity change from 0 to 1073610752
md: delaying resync of md1 until md0 has finished (they share one or more physical units)
md: bind<sda3>
md: bind<sdb3>
md: bind<sdc3>
md: bind<sdd3>
md/raid:md2: not clean -- starting background reconstruction
md/raid:md2: device sdd3 operational as raid disk 3
md/raid:md2: device sdc3 operational as raid disk 2
md/raid:md2: device sdb3 operational as raid disk 1
md/raid:md2: device sda3 operational as raid disk 0
md/raid:md2: allocated 4272kB
md/raid:md2: raid level 5 active with 4 out of 4 devices, algorithm 2
RAID conf printout:
--- level:5 rd:4 wd:4
disk 0, o:1, dev:sda3
disk 1, o:1, dev:sdb3
disk 2, o:1, dev:sdc3
disk 3, o:1, dev:sdd3
md2: detected capacity change from 0 to 8987273330688
md: delaying resync of md2 until md0 has finished (they share one or more physical units)
md2: unknown partition table
md/raid:md2: Disk failure on sdd3, disabling device.
<1>md/raid:md2: Operation continuing on 3 devices.
md: cannot remove active disk sdd3 from md2 ...
md: md0: resync done.
md: resync of RAID array md1
md: using 128k window, over a total of 524224 blocks.
RAID conf printout:
--- level:5 rd:4 wd:3
disk 3, o:0, dev:sdd3
RAID conf printout:
md: delaying resync of md2 until md1 has finished (they share one or more physical units)
RAID1 conf printout:
--- wd:4 rd:4
disk 0, wo:0, o:1, dev:sda1
disk 1, wo:0, o:1, dev:sdb1
disk 2, wo:0, o:1, dev:sdc1
disk 3, wo:0, o:1, dev:sdd1
md: unbind<sdd3>
md: export_rdev(sdd3)
md: bind<sdd3>
md0: unknown partition table
EXT3-fs: barriers not enabled
kjournald starting. Commit interval 5 seconds
EXT3-fs (md0): using internal journal
EXT3-fs (md0): mounted filesystem with ordered data mode
md: md1: resync done.
md: resync of RAID array md2
md: minimum _guaranteed_ speed: 50000 KB/sec/disk.
md: using 128k window, over a total of 2925544704 blocks.
md: md2: resync done.
RAID conf printout:
RAID conf printout:
RAID conf printout:
md: recovery of RAID array md2
md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for recovery.
md1: unknown partition table
Adding 1048444k swap on /dev/md1. Priority:-1 extents:1 across:1048444k
EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
scsi: killing requests for dead queue
udevd version 125 started
ata1.00: configured for UDMA/133
ata1: EH complete
ata2.00: configured for UDMA/133
ata2: EH complete
ata3.00: configured for UDMA/133
ata3: EH complete
ata4.00: configured for UDMA/133
ata4: EH complete
EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: acl,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv1
SMART Information for Disk 4
Model: WDC WD30EFRX-68AX9N0
Serial: WD-WMC1T2686153
Firmware: 80.00A80
SMART Attribute
Raw Read Error Rate 0
Spin Up Time 6266
Start Stop Count 13
Reallocated Sector Count 0
Seek Error Rate 0
Power On Hours 448
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 13
Power-Off Retract Count 11
Load Cycle Count 1
Temperature Celsius 33
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
ATA Error Count 0
- FireWalkerXAspirantDevice is being returned, defined DOA by support
