mgiammarco
Aug 24, 2015Aspirant
Updated to 6.2.5. Started a rebalance, now nas dead
Hello, in the past I had several problems with my readynas 102: system was unstable expecially with nfs/array rebuild and so on. Now I installed os 6.2.5 and things seemed to work better. So I dec...
mdgm-ntgr
Aug 24, 2015NETGEAR Employee Retired
When it tells you your disk is almost full you should check for advice first before running a balance.
Before running a balance you should get volume usage down to the 80-85% range.
Do you have a backup?
- mgiammarcoAug 25, 2015Aspirant
I received the 80% full warning then 90% full warning. Then I checked and freed some space to came back to 80% warning.
So when I started the rebalance the volume was at 80%-85%.
I have backups but recreating and reimporting data in all virtual machines is a very time consuming process.
Anyway I could not understand how I can destroy the nas using an allowed operation from the gui. At least the system should boot. Is the boot partition on btrfs too?
Thanks again,
Mario
- StephenBAug 25, 2015Guru - Experienced User
The OS runs in its own partition, on the RN102 that partition is formatted ext4.
StephenB ha scritto:The OS runs in its own partition, on the RN102 that partition is formatted ext4.
So why it does not boot? I have reinstalled os several times. How can I debug it?
