Thresherinc
Oct 06, 2016Aspirant
Updates 6.5.2 and 6.6.0 reintroduced RN10400 Chrome Upload Problem
I think the issue fixed in this previous release ReadyNAS OS 6.1.5 Release Notes: (Dec 2013) Enhancements & Bug Fixes: Fixed drag and drop file compatibility with Chrome Has been re-introduced ...
JennC
Oct 10, 2016NETGEAR Employee Retired
Hello Thresherinc,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to post the fix and mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- ThresherincMar 24, 2017Aspirant
I stopped trying to use the drag and drop method because it was too flaky.
I'm not sure that telling me it works on yours was a solution.
In the end I reworked the way I use the NAS to get a more permanent fix.
