techman05
May 15, 2011Guide
updates for nti shadow?
My ready nas duo came with this software with my luck all the updates windows 7 is coming out with my copy of nti shadow seems to be having issues like thinking my nas is not up and warning me till I ...
claykin
May 15, 2011Aspirant
NTI Shadow V3.x that came with your Duo is not compatible with Windows 7. Netgear does provide an upgrade path to Shadow V4.x or Memeo Backup. Check the following link for info to upgrade to Memeo. I was not able to find the upgrade link for NTI Shadow.
http://www.readynas.com/?p=2586
In any event, I'm unimpressed with either and recommend you look at another backup solution.
Here's a few:
Quickshadow (written by a forum member) - Both free and paid versions available - http://www.quicklytech.com
Syncback Pro - My favorite. Its accurate, fast and reliable. Plus for home users a single purchase allows install on up to 5 PC's you own. - http://www.2brightsparks.com
Cobian Backup - free, reliable, semi-fast. Lacks restore functionality. http://www.cobiansoft.com
Here's a few:
