techman05
May 15, 2011Guide
updates for nti shadow?
My ready nas duo came with this software with my luck all the updates windows 7 is coming out with my copy of nti shadow seems to be having issues like thinking my nas is not up and warning me till I ...
Tghu_Verd
Dec 21, 2011Aspirant
Apparently Netgear Help Desk are unaware of the incompatibility of NTI Shadow V3 and Windows 7 because mine is way flaky and the suggestion was to reinstall as some other program may have introduced instability.
But I'm looking at CrashPlan as that allows me to back up my PC to the ReadyNAS and to the cloud via a single, cost-effective app (about $120 per annum for unlimited cloud storage. Was using Mozy but their prices went up as storage capacity went down). Requires a bit of fussing around on the Windows 7 so CrashPlan can see the ReadyNAS and back up to it, but overall it should be a neater option because then I can safely centralize storage of my critical data on the ReadyNAS knowing that it's also going up the wire in case of theft, fire or meteor strike!
