lem3ssie
Nov 16, 2012Aspirant
Updating Raidiator
Hi, is it possible to update raidiator via ssh ?, without accessing dashboard cause I can't anymore. Thanks
mdgm-ntgr
Nov 17, 2012NETGEAR Employee Retired
That's probably not enough to check.
Can you try restarting the Dasbhoard
and see if that brings it back up?
Another thing you could try is
# /usr/sbin/apache-ssl -f /etc/frontview/apache/httpd.conf -t && /usr/sbin/apache-ssl -f /etc/frontview/apache/httpd.conf -k graceful
vi /etc/default/services
Then change the value in the line for e.g. sickbeard from 1 to 0. Save your changes then try restarting the Dashboard again.
Note I don't think Python can be disabled and you already have the latest version installed. Don't try disabling Python.
We want to rule out if possible a compatibility issue with an add-on preventing it from booting up.
