ulfrickardsson
Oct 17, 2012Aspirant
Updating Readynas duo from 1 to 2tb not easy
Hello I thought it would be easy to upgrade my Readynas v1 from 2 1tb to 2 tb. As instructed, I just replace one of the 1tb disks with 1 2tb disk. 8 hours later a get a message that it is fully ...
Oct 17, 2012Guru - Experienced User
Perhaps you should open a on-line support case (which is free).
What firmware is your V1 running?
BTW, you might want to update your profile to indicate the NAS you actually own.
