fondy
Mar 31, 2025Tutor
ReadyNAS 6.10.8 (RN524X) - Timeout when checking for updates
Hi
Check for Updates from my 524X I got error:
"Cannot connect. Communicatins error. Check your internet connections, DNS Settings, or Proxy settings"
All was OK some weeks ago
PS. I see a green "internet available" indication on the cloud page
Please help
regards Paal
This is Netgear's issue - they appear to have taken down the update server.
You should probably install at least 6.10.9 manually
If you don't use the apps page in the web, I suggest installing 6.10.10
6.10.10 is the most recent release.
1 Reply
