nightfly1
Sep 28, 2011Aspirant
Upgrade 2150 Readynas Duo to 2 TB drives
I have a Readynas Duo 2150 I purchased a few years ago. It's 500 Gb drive reached 90% full, so I wanted to upgrade the discs. I purchased two seagate drives which were on the approved hardware list. ...
nightfly1
Sep 29, 2011Aspirant
Everything seems to be working fine now with the two 2 tb disks. Thank you. for anyone else going through this, be aware that after the factory reset, with the 2, 2 terabyte disks in the NAS, it took nearly 10 hours for the device to format and set up the device until it was finished; the act led and the channel 2 light seemed to go on blinking forever, I was wondering if something was wrong. but I let it run itself, and it worked out fine. Just be patient and it will finish setting itself up.
Thanks for the advice, mdgm. I changed the subject field of the initial post so that this thread information will show up on a google search for others to see. It would have saved me several days of work if I had found it.
