Numb3r6
Nov 29, 2015Apprentice
ReadyNAS Duo RND2000 drive upgrade
I'm looking to replace drives and increase capacity in my ReadyNAS Duo RND2000. The unit itself has been reliable, particularly after hooking it up to a UPS
Currently I have 2x1TB Seagate Barracuda drives (ST31000520AS) and they've been fine, I just need more space.
One aspect I'm unsure about, and would appreciate some thoughts on, is the importance of Rotational Vibration Safeguard, as not opting for that opens up the range of compatible HDDs. One that looks good value for money is the WD Caviar Green WD20EARX.
I'd appreciate any thoughts/suggestions especially based on first hand experience of going 2TB and up on this chassis
Thanks!
I have several Duos. I recently upped one from 2x1TB (X-RAIDed) to 2x 2TB. It was a very easy process, but did take a few days.
I use these drives "Seagate Barracuda 3.5 inch 2TB 7200 RPM 64MB 6GB/S Internal SATA Drive" (from Amazon.co.uk)
(Not saying these drives are right for you, but they are what I have had success with - YMMV).
The upgrade is easy:
1. Power down and replace drive 2 with a new 2TB drive.
2. Power up and let the RAID sort itself out.
3. Repeat steps 1 & 2 for drive 1.
4. When RAID is all sorted, reboot again to have the X-RAID expand the volume to 2TB.
5. Job done!
It is very straight forward but takes days, and as you probably already know, make sure you have a backup of ALL your data before you start.
Good luck,
Ian
- ilneillApprentice
5. Job done!
Good luck,
Ian
I'm not a fan of the "DM" seagates - there have been too many issues reported with them here. I also don't recommend green drives (WDC or Seagate) in a NAS. The WDC red drives (or the Seagate VN equivalent) are similar in price, are targetted for home NAS, and have better warranties.
My Duo is running with one older Seagate (a 4 year old ST32000542AS) and a Western Digital WD20EFRX (installed for about 18 months). The Duo v1 isn't fast enough to benefit much from 7200 RPM, and the WDC Reds run much cooler/use less power than the 7200 drives. So I'd go with the WD20EFRX myself.
- Numb3r6Apprentice
Thanks for the replies guys. TBH I think I may have left drive upgrade a bit late as it seems suitable drives with RVS are becoming in short supply due to evolution I suppose. Having said that I somewhat feel that kit manufacture has come along and regular drives are likely to be quite reliable if a decent brand is picked. It's not as if the location of my NAS is one where it is getting knocked about either. Though I understand some of the RVS thing relates to drive<>drive vibration in the chassis too.
Coincidentally the Barracudas mentioned by ilneill had drawn my eye previously, nice cache, xfer rate and nice price to boot. However some of the reviews are a bit scary, and that's even after excluding the ones that are being used as external HDDs rather than sat in a NAS box. The customer feedback seems to be polarised and when bad, it seems very bad, right down to the packaging. I even wonder if some are sneaky recons. I used to buy hundreds of HDDs when I did a lot of storage management and even in that environment the failure rate was very low, but perhaps my route of purchase was more direct to elude any potential dodgy goings on.
How long have you been running these and have any errors shown?
As I've not swapped out any of mine before I was interested to read that you can just swap 1 for the bigger unit, let it sort itself, then finalise the mirror by banging the 2nd bigger one in. For some reason I was under the impression that with the Duo, you ditched both drives, set up a new pair, then restored data to the mirror set. In terms of emergency rollback I would of course have my original pair of 1TB units
As for the WD WD20EFRX mentioned by StephenB, I'd not seen that as I'd been focusing on the Netgear HCL and that model is not included. However the feedback seems consistently better and I do like the angle WD play saying they will work in whatever NAS you use. Bold, and I've not had any issues with WD kit in the past either. Interestingly I see a Q and someone has replied saying they have them in their Duo.
Hmm right now I think I can see where this is going...subject to a bit more reading on the WD Red to see if specific compatibility with Duo is mentioned, maybe even up to 3TB
Cheers again guys, as ever this is a helpful and knowledgeable place to discuss issues.
As and when I make a decision I'll be sure to share results. :-)- StephenBGuru - Experienced User
3 TB will certainly not work in the duo v1. It doesn't support GPT formatting, so it is limited to 2 TB.
- Numb3r6Apprentice
Yeah I was beginning to suspect that limitation, but as I'm only about 75% full on 1TB, I reckon the move to 2TB will last some time. Incidentally I read up some more on the WD Red series and learnt that they pretty much have their own flavour of vibration protection built in, and the Duo v1 is listed as a tested chassis. So all in all, they sound like a good tip you've suggested!
- Numb3r6Apprentice
Quick update which may benefit others going down same route.
WD Reds arrived last night. Out of habit I left them to one side for a couple of hours to come up to room temp. Well, I went to the pub :-)
Started the process on return, on bay2, and let things run. Got up this morning to see first stage had completed a couple of hours previously. Replaced bay1, wait some more. Got prompts for each stage finalising in a couple of reboots leading to completed expansion. Total elapsed just short of 24hrs given the 1TB set was just over 80% full. So far looking ok :-)
- BrianL2NETGEAR Employee Retired
Hi Numb3r6,
Thanks for the feedback. You may now tag this topic as resolved by clicking the "Accept as Solution" in one of the responses on the said thread.
Kind regards,
BrianL
NETGEAR Community Team
