Numb3r6
Nov 29, 2015Apprentice
ReadyNAS Duo RND2000 drive upgrade
I'm looking to replace drives and increase capacity in my ReadyNAS Duo RND2000. The unit itself has been reliable, particularly after hooking it up to a UPS Currently I have 2x1TB Seagate Barracud...
- Nov 29, 2015
I have several Duos. I recently upped one from 2x1TB (X-RAIDed) to 2x 2TB. It was a very easy process, but did take a few days.
I use these drives "Seagate Barracuda 3.5 inch 2TB 7200 RPM 64MB 6GB/S Internal SATA Drive" (from Amazon.co.uk)
(Not saying these drives are right for you, but they are what I have had success with - YMMV).
The upgrade is easy:
1. Power down and replace drive 2 with a new 2TB drive.
2. Power up and let the RAID sort itself out.
3. Repeat steps 1 & 2 for drive 1.
4. When RAID is all sorted, reboot again to have the X-RAID expand the volume to 2TB.
5. Job done!
It is very straight forward but takes days, and as you probably already know, make sure you have a backup of ALL your data before you start.
Good luck,
Ian
Numb3r6
Dec 06, 2015Apprentice
Quick update which may benefit others going down same route.
WD Reds arrived last night. Out of habit I left them to one side for a couple of hours to come up to room temp. Well, I went to the pub :-)
Started the process on return, on bay2, and let things run. Got up this morning to see first stage had completed a couple of hours previously. Replaced bay1, wait some more. Got prompts for each stage finalising in a couple of reboots leading to completed expansion. Total elapsed just short of 24hrs given the 1TB set was just over 80% full. So far looking ok :-)
- BrianL2Dec 06, 2015NETGEAR Employee Retired
Hi Numb3r6,
Thanks for the feedback. You may now tag this topic as resolved by clicking the "Accept as Solution" in one of the responses on the said thread.
Kind regards,
BrianL
NETGEAR Community Team
