heyfrank
Oct 23, 2015Follower
Upgrade Drives on NETGEAR READYNAS DUO v2
Hi I'm looking to upgrade my NETGEAR READYNAS DUO v2 hard drives. Currently they sit in a X-RAID 2. I want to know the procedure for doing this, and if it's possible to do it as a hot swap. ...
nightfly44
Feb 10, 2016Apprentice
Nope, nothing was done. It's now after 12 am and nothing has changed. For the meantime I'm just going to let it sit. What gets me, is that it worked fine with one drive in it. Adding the second, or resetting it with two gave me trouble. Like I wrote before, I suspect I did something to it because I accessed it during the initial synch. Tomorrow, reset and no-touch until it's done setting itself up completely.
JennC
Feb 10, 2016NETGEAR Employee Retired
Hello nightfly44,
How about clearing cache? Then reboot computer and try to access the admin page again?
- nightfly44Feb 13, 2016Apprentice
OK. In another search, I found this, it appears that all this has been gone over before by other people with the same problem. Perhaps you can access the transcripts of what support was done with this user and we can try that. Here's the link: https://community.netgear.com/t5/Using-your-ReadyNAS/Duo-v2-Device-is-Offline/td-p/915468/page/2
- JennCFeb 13, 2016NETGEAR Employee Retired
Hello nightfly44,
The topic in that link is about Device Offline where it does not ask for login details. May I ask what login details are you entering to access the admin page? By default it is just admin for username and password for password, since you have performed OS reinstall, it should be using that default login.
If same problem, since you can still access the data, backup all the data so you can factory reset the NAS with the disks inserted. This will allow you to create a new volume with all the disks you want it to use then restore the data.
- nightfly44Feb 15, 2016Apprentice
I've been doing that. At the moment, I've taken a breather from working on it, as nothing so far has solved the problem. Next step I guess is to restore the OS from usb.
Basically, if I install one disk at a time, I get one huge volume, not raid 1, and cannot convert it to raid one. I can access all the rest of the web page, but not change it to raid 1 (as it was not an option when I installed the first drive by itself, just raid 0 or jbod). If I install with both drives in, I get raid 1 (I suppose) with both disks showing working normally in raidar, but cannot access the front page in the web interface. I have tried using admin and password, admin and netgear1, admin and journal (journal is my default password for initial setup of everything I do, and I change it once everything is functional). I have so far tried installing the drives one at a time twice, each time resetting to factory default inbetween. I have tried installing with both drives in three times, also resetting to factory default before initializing. I had thought that accessing the nas while it was syncing perhaps was corrupting something, so the last time around, I left it alone until it was done. But that hasn't changed anything. I have tried to access the nas with intenet explorer, firefox, and chrome. I have cleared the cache in each. I was still getting the device offline message. I'll write back after I reinstall the os and go through the whole process again.
- StephenBFeb 16, 2016Guru - Experienced User
Are you in flexraid or xraid?
netgear1 is for the duo v1, and you have a v2. The default password on the v2 is "password".
If you do a factory reset with all disks in place, you should have a 10 minute window to set up the RAID configuration you want. You need RAIDar for that (and I suggest 4.3.8, not 6.x).
- nightfly44Feb 18, 2016Apprentice
OK Jenn, numerous attempts at this but similar results. Tried it again, this time one disk at a time after reset to factory defaults. Again accessed the nas via web interface, set time zone, set nas name, set password, set email, get to the end, and I get the little spinning thing, then.....it stops. gives me the little white box which says Authentication Required, The server https://192.168.1.10 requests a username and password. The server says: Control Panel (it changed it's address around this time, I suppose it requested it and my router assigned it automatically). The it won't accept admin and either the word password or the password I had tried to change it to, which is journal, whenever I try I keep getting the white box back with the fields empty. I tried AGAIN emptying the cache, and again with internet explorer, firefox, chrome, and added in opera this time. NO go. I'm going to pull the drives and replace with the initial 1 TB seagate. drive. reset and try again. Maybe it just doesn't like WD red 4Tb drives.
- JennCFeb 18, 2016NETGEAR Employee Retired
Hello nightfly44,
How about OS reinstall again, then use the default password when logging back in once you are in, change the password in the dashboard. This time is it not through the setup wizard but in the dashboard.
- nightfly44Feb 20, 2016Apprentice
OK Jenn, Here's what worked: I'm not a programmer, so I don't understand the underlying problems with how all this worked.
Took out both 4TB drives. Installed the 1TB WD10EARX green drive that shipped with the device into the left drive bay. Let it set itself up. Everything went ok, it set itself up into x-raid2 without any choices offered to me. I watched the goings on with Raidar 6.1. Shut it down, and let it reboot. Installed one of the 4TB WDEFRX drives. The nas recognised it, and mirrored the 1TB partition on the first drive, web page says it's redundant. Shut it down. Removed the 1TB drive. Rebooted. Still able to see it under raidar and web page. Installed the second 4TB drive into the left slot while hot. Then it took it's usual time to mirror the 1TB partition. Following directions, I waited until it was done, and shut it down. Upon reboot, it expanded the mirrored partition to it's full size. Here's the logs, though the web page here changed something that included network addresses. If you want, I can download the logs that I kept and send them to you for archiving should anyone need them, as I don't see a way to attach the logs to this post. Here's what it will allow me to post:
Sat Feb 20 00:56:17 EST 2016 RAID sync finished on volume C. Fri Feb 19 16:06:30 EST 2016 Data volume has been successfully expanded to 3696 GB. Fri Feb 19 13:46:11 EST 2016 System is up. Fri Feb 19 13:45:34 EST 2016 Continuing with volume expansion. Do not interrupt the system during this time. When complete, email notification will be sent to the alert contact list. Fri Feb 19 13:15:48 EST 2016 Found space that can be used to expand capacity, expansion process will start during next boot. Fri Feb 19 13:14:46 EST 2016 Found space that can be used to expand capacity, expansion process will start during next boot. Fri Feb 19 13:13:59 EST 2016 Found space that can be used to expand capacity, expansion process will start during next boot. Fri Feb 19 13:13:50 EST 2016 RAID sync finished on volume C. Fri Feb 19 11:05:47 EST 2016 RAID sync started on volume C. Fri Feb 19 11:05:26 EST 2016 Data volume will be rebuilt with disk 1. Fri Feb 19 11:05:18 EST 2016 New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 1] Fri Feb 19 11:02:52 EST 2016 System is up. Fri Feb 19 10:01:00 EST 2016 RAID sync finished on volume C. Fri Feb 19 06:38:42 EST 2016 Automatic disk spin-down disabled. Fri Feb 19 06:38:40 EST 2016 Automatic disk spin-down enabled. Fri Feb 19 06:37:17 EST 2016 RAID sync started on volume C. Fri Feb 19 06:36:09 EST 2016 Data volume will be rebuilt with disk 2. Fri Feb 19 06:36:00 EST 2016 New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 2] Fri Feb 19 06:34:58 EST 2016 ReadyNAS is set to local user mode. Fri Feb 19 06:32:41 EST 2016 Alert settings saved. Fri Feb 19 06:32:41 EST 2016 Alert contact(s) saved. Thu Feb 18 17:53:28 EST 2016 System is up. Thu Feb 18 16:08:12 EST 2016 Alert settings saved. Thu Feb 18 16:08:12 EST 2016 Alert contact(s) saved. Thu Feb 18 13:06:48 PST 2016 Alert test message has been sent. Thu Feb 18 12:59:42 PST 2016 System is up. Thu Feb 18 12:58:54 PST 2016 Successfully upgraded ReadyNAS Photos II addon package (version: 1.0.6 --> 1.0.6) Thu Feb 18 12:56:48 2016 Firmware on disks has been updated to match the system. - BrianL2Feb 21, 2016NETGEAR Employee Retired
Hi nightfly44,
Base from what you said and in the log sequence that you posted, the system appears to be fully functional now with your 2x 4TB hard drives.
Let us know if you have further questions.
Kind regards,
BrianL
NETGEAR Community Team
