bstuke
Jan 02, 2020Aspirant
Upgrade files to go from 4.2.31 toOS6 on a Ultra?
I am looking for the files to upgrade an Ultra 6 to OS6. None of the links in previous threads work. TIA
Marc_V
Jan 02, 2020NETGEAR Employee Retired
Welcome to theCommunity!
Not really supported by NETGEAR and you will have to go here in the Community once you upgrade your OS 4 to OS 6.
Here's a link I have, not sure if this is still okay.
HTH
Regards
- bstukeJan 02, 2020Aspirant
Marc_V That worked, thanks.
I am aware of the non support. Buying a RN428 and want to see how the new OS works.
- StephenBJan 02, 2020Guru - Experienced User
Working links are also here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-R4toR6-download-links/m-p/1649129#M150271
