bstuke
Jan 02, 2020Aspirant
Upgrade files to go from 4.2.31 toOS6 on a Ultra?
I am looking for the files to upgrade an Ultra 6 to OS6. None of the links in previous threads work. TIA
Marc_V
Jan 02, 2020NETGEAR Employee Retired
Welcome to theCommunity!
Not really supported by NETGEAR and you will have to go here in the Community once you upgrade your OS 4 to OS 6.
Here's a link I have, not sure if this is still okay.
HTH
Regards
bstuke
Marc_V That worked, thanks.
I am aware of the non support. Buying a RN428 and want to see how the new OS works.
- StephenBJan 02, 2020Guru - Experienced User
Working links are also here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-R4toR6-download-links/m-p/1649129#M150271
- BastianWtalJan 11, 2020Aspirant
Maybe you also wish to check if the bios is up to date (which needs to be updated separatly and didn´t comes with the firmware upgrade!). I performed that after the OS6 upgrade (from 4.x) which solved some issues for me. So you might try to wish to do the same. The URL I used for the ReadyNAS Bios Upgrade process is: https://www.admin-enclave.com/en/articles/linux/484-upgrade-the-bios-from-an-readynas-device.html
