Pottsy1
Jan 10, 2015Aspirant
Upgrade from RN102 to RN104
Hi all, I have the RN102 with two 3T drives on OS 6.2. Each formatted to FexRaid JBOD. I want to expand to the RN104. Will it be as simple as moving the two drives over to the new box or will I ha...
Feb 28, 2015Guru - Experienced User
Generally if you migrate disks, The ReadyNAS will try to install the firmware in its flash onto the drives. Since you can't downgrade from 6.2 to 6.1.6 that could be a problem.
