Pottsy1
Jan 10, 2015Aspirant
Upgrade from RN102 to RN104
Hi all, I have the RN102 with two 3T drives on OS 6.2. Each formatted to FexRaid JBOD. I want to expand to the RN104. Will it be as simple as moving the two drives over to the new box or will I ha...
CharlesR
Feb 28, 2015Guide
I have migrated a ton of (older Legacy) units and just to play it safe I upgrade both to the same version before I swap drives. If the new unit is older I use a temp drive to upgrade it. In your case with the new unit being newer can't you simply update the older unit to the same level?
