IDATAAB
Oct 08, 2018Follower
Upgrade legacy to OS6
Recently upgraded a 2100 V1 and 3200 to OS 6.9.4 from Raidiator 4.2.31.
My question is - once upgraded do I need to modify the header of any future 6.9.x updates before installing them or can I jus...
Oct 08, 2018Guru - Experienced User
You just install the update, no changes are needed.
Of course you can also use "check for updates" directly, so you don't have to download and manually install.
- DKU62Oct 08, 2018AspirantHi Stephen,
I want to upgrade my legacy readynas from raidiator 4.2.x to 6.2.x
But I can’t find the files:
PREPR4TOR6_0.1-x86.bin
R4toR6_6.9.3.bin
Can you help me with a tip ?- StephenBOct 08, 2018Guru - Experienced User
R4toR6_6.9.3.bin
Can you help me with a tip ?You'll find links here: https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyNAS-R4toR6-download-links/m-p/1649129#M150271
- Sep 05, 2015Retired_Member
