IDATAAB
Oct 08, 2018Follower
Upgrade legacy to OS6
Recently upgraded a 2100 V1 and 3200 to OS 6.9.4 from Raidiator 4.2.31.
My question is - once upgraded do I need to modify the header of any future 6.9.x updates before installing them or can I jus...
Oct 08, 2018Guru - Experienced User
You just install the update, no changes are needed.
Of course you can also use "check for updates" directly, so you don't have to download and manually install.
DKU62
Oct 08, 2018Aspirant
Hi Stephen,
I want to upgrade my legacy readynas from raidiator 4.2.x to 6.2.x
But I can’t find the files:
PREPR4TOR6_0.1-x86.bin
R4toR6_6.9.3.bin
Can you help me with a tip ?
R4toR6_6.9.3.bin
- StephenBOct 08, 2018Guru - Experienced User
R4toR6_6.9.3.bin
Can you help me with a tip ?You'll find links here: https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyNAS-R4toR6-download-links/m-p/1649129#M150271
- Sep 05, 2015Retired_Member
