celicajames
Feb 09, 2014Follower
Upgrade to better nas
Hi, I currently have a nv+ v2 and I'm not overly happy with the performance, I stream Blu-ray files to a dune player and occasionally it struggles (I have a 2tb buffalo nas that has double the perform...
Feb 09, 2014Guru - Experienced User
You shouldn't be having any problems streaming BluRay from a NV+ v2 to a Dune. BluRay requires a max of 7 MB/s, the NV+ v2 can easily stream at 10x that speed.
I think something else is going on.
One possibility is that an add-on is interfering with the performance.
Another might be that your switch/router doesn't support 802.3x flow control control. What model Dune do you have? Does it have a gigabit NIC or 100 mbit? What switch/router are you using?
