dansel's avatar
dansel
Upgrade Ultra 4 and Pro 4 OS 4.2.31 to 6.9.3
Hi, I've finally decided to take the plunge to upgrade my OS4-devices to OS6. It seems quite hard to find a reliable source for the needed upgrade files (PREP4TOR6 and R4toR6*.bin).   Is there ...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Aug 21, 2018
    You’ve already got the latest BiOS for your system installed. So there’s no benefit at all from installing the BIOS update add-on.
    Even if you had an old BIOS updating the BIOS would not have been essential, just optional.
ProSupport for Business
