Marcel_X
Jun 06, 2016Aspirant
Upgrading NV+ to RN214
I'm about to replace my old NV+ after many years service. The performance leaves a lot to desire and the incidental "Booting, please wait..." lock-up, freaks me out. Unfortunately I can't afford abo...
- Jun 07, 2016
Marcel_X wrote:
Thanks for the reply!
Can I start with one drive, put my data on it and upgrade with extra drives over time, without restoring or losing the data?
Is it possible to add drives like; start with 1 drive and no RAID, expand to 2 drives RAID 1, 3 drives RAID 3-5 and finaly 4 drives RAID 6?
XRAID will handle the migration from jbod->RAID 1-> RAID 5 automatically. You just insert the new disks.
You can then change to flexraid to get to RAID-6 on the last drive. There is no data loss (note all drives will need to be the same size if you want to land on RAID-6). After the RAID-6 array is built, you can change back to XRAID (or not).
Marcel_X
Jun 07, 2016Aspirant
Jun 07, 2016Guru - Experienced User
