Equinox1
May 29, 2019Guide
Upgrading to 6.10.1
This morning I was prompted to update to 6.10.1, and so i did (from 6.10.0HF2) After the classical double reboot, the unit is stuck in a state where the screen says “Rebooting: upgrading FW” for a ...
- Jun 19, 2019
Hi guys,
Despite the zero intereste or guidance from Netgear members on this forum, I managed to put the Pro 6 back online.
I indeed used the boot menu, with the option “Reinstall OS”; it took ages, but it brought the NAS back to life. Little huge detail: the RAID array had to be synced up once it was back online (and it took an extra 8 hours).
It’s the 3rd OS upgrade that breaks this NAS...
Equinox1
Jun 19, 2019Guide
Hi guys,
ahpsi1
Jun 19, 2019Tutor
Interesting, of all the units I have used/managed the Pro 6 has been the most stable, even after upgrading to OS 6. Do you think the drives might be involved? I've seen issues when one has some SMART errors, even when not failed. Regardless, glad you recovered the unit!
- tony359Jun 20, 2019Apprentice
I updated my Pro6 yesterday and all went well. I only have CrashPlan on my NAS, everything else is stock. I rebooted the NAS before updating, just in case.
- Equinox1Jun 20, 2019Guide
ahpsi1 , completely agree! The Pro6 is a rock-solid machine, and to prove it, I own 3 of them! At different levels of customization, from stock to new CPU/RAM/cooling gear.
I have no reason to suspect any malfunction of the drives, or at least from the main array (5x2Tb drives in RAID6), plus a scratch disk for swap, downloads, cloud, etc... The scratch disk is a 2TB WD Green drive, so clearly not a NAS drive.
I suspect that there is some weak point in the current 6.9/6.10 OS upgrading procedure, that makes these hickups happen. Glad to share diagnostics from my system, if somebody would care to have a look.
- tony359Jun 21, 2019Apprentice
I care! But I am not an expert so I don't know if I can make anything from that.
