davidr1
Jun 21, 2017Luminary
UPS and Power Chute and SNMP?
For tax reasons I need to purchase a UPS imminently - apart from the fact it is a very good idea to have one! I use Linux (Ubuntu 16.04), Pro2, Ultra2 (both OS6) and 31400 NAS I know nothing ...
- Jul 07, 2017
sounds like your UPS might have gotten fried.
Since you have 2 UPS, you could swap them and see if the other nas will recognize it.
If they both work on different nas, then perhaps something wonky with the config, but if the bad one still doesn't work, then I guess you need to replace it.
hmuessig
Jun 22, 2017Luminary
So what happens if you have two units (314 and 716x in my case) with only one (the 716x) connected via USB to a UPS?
Is there any way a second unit (the 314) can "know" when the UPS switched on? Network monitoring of the UPS is checked on the 716x . . .
Jun 22, 2017Guru - Experienced User
The RN314 can monitor the UPS using the 716x as a proxy. On the RN314 you specify "remote UPS".
This uses the network connection, so you need to make sure the network path is also protected (ideally by the same UPS).
I'm not sure what you mean by knowing when the UPS is switched on. The NAS knows that the UPS is functioning, whether it is using battery power or not, and the estimated run time. And it will execute a clean shutdown when the battery drain threshold is reached.
