davidr1
Jun 21, 2017Luminary
UPS and Power Chute and SNMP?
For tax reasons I need to purchase a UPS imminently - apart from the fact it is a very good idea to have one! I use Linux (Ubuntu 16.04), Pro2, Ultra2 (both OS6) and 31400 NAS I know nothing ...
- Jul 07, 2017
sounds like your UPS might have gotten fried.
Since you have 2 UPS, you could swap them and see if the other nas will recognize it.
If they both work on different nas, then perhaps something wonky with the config, but if the bad one still doesn't work, then I guess you need to replace it.
Sandshark
Jul 07, 2017Sensei
The defaults are the ones in /etc/default/config/etc/nut/.
TeknoJnky
Jul 07, 2017Hero
- davidr1Jul 07, 2017Luminary
Hi TeknoJnky
I had already tried that as step one but decided to try it again.
It worked.
Can not explain why.
Both units were only bought 30 Jun - not good one fried after a power failure.
Many thanks SandShark for telling me where the default files are.
Many thanks to all ... it is very much appreciated.
- davidr1Jul 10, 2017Luminary
UPDATE:
Fried UPS returned and replaced ....
