kmcmullin
Dec 21, 2015Aspirant
USB backup knocks ReadyNAS offline
Hi- A couple of weeks ago I updated the firmware on the ReadyNAS. I can run Symantec System Recovery 2013 from my server to the NAS just fine but if I backup files from the NAS to an external hard dr...
mdgm-ntgr
Dec 22, 2015NETGEAR Employee Retired
If that does not resolve it you may wish to try downgrading to 6.4.0 to see if that resolves the problem.
kmcmullin
Dec 22, 2015Aspirant
How do I do that?
- StephenBDec 22, 2015Guru - Experienced User
kmcmullin wrote:
How do I do that?
download the zip from http://kb.netgear.com/app/answers/detail/a_id/29938/~/readynas-os-version-6.4.0 and extract the image file.
Then install it using the web ui (system->settings has a manual install control).
