chickensoup's avatar
Jun 02, 2016
USB connected UPS
I have several SOHO clients using the ReadyNAS RN31200 with a USB connected UPS.  These UPSs used to work with onpremise Windows Servers and now just using them as battery backup for the NAS devices....
  • StephenB's avatar
    Jun 05, 2016
    chickensoup wrote:
    Thanks StepenB for the reply. So can you confirm that if a USB connected UPS has a power failure then the ReadyNAS will gracefully power down?
    The ReadyNAS has the NUT software (network ups tools) built in, and it will gracefully shut down when the NAS receives power-criticial from the UPS.
    You will also see the current UPS status on the UI (it should show UPS model, battery status, and whether you are using battery or not).  Loss of power is logged (and if the power outage doesn't drain the UPS battery, so is power restoration).
    I use cyperpower myself, as Ian says APC is works and is popular.  You need to ensure you get a UPS with a USB cable, not one that uses the older serial link.
    See page 200-205 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
ProSupport for Business
